Old 02-24-2020, 06:50 PM   #1
cas3
Default steering column wire clips
i've installed an old turn signal switch on the 34, a signal stat 700. i want a clip that holds the wire harness to the side of the column. it seems to me my old 63 ford truck had a clip like that for the factory signal wires, and i think many others, like 50's gm stuff too. its a C shape with a bump out the back for wires to go thru, and just clips on the tube. i checked all the ford vendors, cant even find a picture. googling brings up more clips than you ever thought existed, but plain old C clips, no. help my memory, was that a ford truck part? is there a proper name to search? any ideas? thanks, skip
Old 02-24-2020, 07:21 PM   #2
19Fordy
19Fordy's Avatar
Default Re: steering column wire clips
I bet you could make one using the metal banding strap material.
Old 02-24-2020, 07:27 PM   #3
cas3
i had thought of that too, even have a piece in stock. its kinda wimpy, i think the real deal was thicker
Old 02-24-2020, 07:58 PM   #4
tubman
tubman's Avatar
I know exactly what you are referring to, but have no idea of what they are called or where to get them. Sorry. The only thing I can suggest are the manufacturers of aftermarket turn signal kits or maybe column mount tachometers.
Old 02-24-2020, 08:01 PM   #5
JSeery
JSeery's Avatar
There was a thread on these a while back. Don't remember if it was here on the Barn or on the HAMB. Not much help, because I can not think of what they were called!
Old 02-24-2020, 09:49 PM   #6
cmbrucew
cmbrucew's Avatar
I would expect the guys into old GM products to have them.
Maybe at a swap meet.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 02-24-2020, 11:10 PM   #7
MMB
No relation, but possibly helpful:
eBay item number:172710393909
MMB is offline   Reply With Quote
Old 02-24-2020, 11:48 PM   #8
cas3
boy, thats the combat duty clip there! https://www.ebay.com/itm/N-O-S-M151-...MUTT-G838-N-O- if i had one here, i would probably use it. i have some jeep stuff, i'll go shopping here tomorrow. also, midwest military is 20 miles away. thanks for looking
Old 02-25-2020, 09:48 AM   #9
JSeery
JSeery's Avatar
Found the link!
https://www.fordbarn.com/forum/showt...highlight=clip
Old 02-25-2020, 11:27 AM   #10
cas3
thanks for your effort J. now i also know my memory has not completely abandoned me yet. i sat behind the wheel of that 63 ford truck for 18 years looking at the clip!
Old 02-25-2020, 12:04 PM   #11
Doublepumper
Doublepumper's Avatar
I bought one of these for my project....works perfectly.
https://www.ebay.com/itm/N-O-S-M151-...S/172710393909
Doublepumper is offline   Reply With Quote
Old 02-25-2020, 12:58 PM   #12
G.M.
I made them out of banding straps, very easy. G.M.
www.fordcollector.com
Old 02-25-2020, 02:46 PM   #13
deuce lover
deuce lover's Avatar
Here you go cas.He has only 2 left so hurry!!
https://www.ebay.com/itm/New-NOS-For...sAAOSwkW5eSErY
Old 02-25-2020, 03:03 PM   #14
JSeery
JSeery's Avatar
I would think the salvage yards would have them.
Old 02-25-2020, 05:31 PM   #15
TJ
TJ's Avatar
Mid Fifty F-100 Parts in Arizona has the clamps. Part # 2919-L $6.90 ea. Ph# 1-800-252-1956. www.midfifty.com.
Old 02-25-2020, 05:44 PM   #16
JSeery
JSeery's Avatar
Here is the clamp (source TJ posted).
Old 02-25-2020, 05:48 PM   #17
petehoovie
petehoovie's Avatar
www.midfifty.com.
Old 02-25-2020, 06:05 PM   #18
cas3
geez, lots of input here, thanks folks!!! looks like midfifty ford is the way to go. thanks all, skip
