Old 05-26-2016, 05:49 AM   #1
1929
Default Throttle Balls?
Who sells throttle balls, not throttle joints or Holley Balls which are short on the thread, need about 3/4 of an inch thread with a ball end that will fit in the throttle rod.
1929 is offline   Reply With Quote
Old 05-26-2016, 06:11 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Throttle Balls?
Like this one??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-26-2016, 06:20 AM   #3
1929
Originally Posted by BRENT in 10-uh-C View Post
Like this one??
yes, must be made of Gold for that price
Old 05-26-2016, 06:35 AM   #4
emf
emf's Avatar
Try McMaster Carr
emf is offline   Reply With Quote
Old 05-26-2016, 07:21 AM   #5
Sparky
Sparky's Avatar
Snyder's has them for $2.95
http://www.snydersantiqueauto.com/linkage-ball-stud
Sparky is offline   Reply With Quote
Old 05-26-2016, 08:46 AM   #6
Utopia Texas
Utopia Texas's Avatar
I always though someone with throttle balls was anyone who had driven their Model A over 60 mph!
Utopia Texas is offline   Reply With Quote
Old 05-26-2016, 09:03 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Whut ur "BALLS"??---Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 05-26-2016, 09:49 AM   #8
31Tudor
31Tudor's Avatar
Chuck in the Swap meet section is selling throttle assemblies, on page 4 right now. You could get an original one from him and then cut it off however you want.
31Tudor is offline   Reply With Quote
Old 05-26-2016, 05:19 PM   #9
1929
Originally Posted by Sparky View Post
would of been perfect if just a little longer, this one is only 7/16
Old 05-26-2016, 05:22 PM   #10
CarlG
CarlG's Avatar
Google "Throttle Linkage" There are quite a few out there. (Even on eBay)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-26-2016, 05:27 PM   #11
1929
the picture that #5 shows is perfect , but still a little short, most on ebay are still short, like the Holleys.
Old 05-26-2016, 06:56 PM   #12
Sparky
Sparky's Avatar
How about if you cut off the thread, drill and tap the ball, insert a longer threaded rod or use a bolt.
Old 05-26-2016, 09:14 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Check out cabinet hardware, as I've seen ball headed screws used on doors.
Old 05-26-2016, 10:42 PM   #14
Bob from Northport
Bob from Northport's Avatar
Any of the speed shop parts catalogs have a variety of them.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 05-26-2016, 10:51 PM   #15
denis4x4
denis4x4's Avatar
Speedway, Jegs, Summit, The Hot Rod Company are just a few of the places you can get they for a couple of bucks each.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 05-27-2016, 08:57 AM   #16
MikeK
MikeK's Avatar
Start with the 7/16 long piece from the vendor, add a 10-32 coupling nut, about 3/4 long, and another piece of 10-32 thread rod from a screw or bolt. You can use lock nuts, red locktite, or JB to hold the assembly together. If necessary the coupling nut can be shortened. You need 5 threads engagement on a 10-32 for full strength, just 5/32 of an inch.
MikeK is offline   Reply With Quote
