Old 03-11-2016, 01:39 AM   #21
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Oh No! Now how am I going to fix this!
As mentioned, that engine needs to come apart and get a thorough cleaning. Then I'd also try the adhesive. If the broken parts later came loose, they'd just lay in the valve galley. You could even lay a strong magnet next to the broken area to catch the parts if they did break off again.
Old 03-11-2016, 03:50 AM   #22
colin1928
colin1928's Avatar
If it were mine I bore out and install a sleeve
colin1928 is offline   Reply With Quote
Old 03-11-2016, 03:51 AM   #23
Dodge
I would bore the hole out a bit and make a stepped sleeve and press it in. Turn the
drive housing down a bit and you would be good to go. It will take some tricky machining
to get down in the block but I think I could be done. I'd try it if it were mine.
Dodge is offline   Reply With Quote
Old 03-11-2016, 08:31 AM   #24
Kurt in NJ
Kurt in NJ's Avatar
I would consider a mechanical repair, take a long bolt, 2 washers, cut a notch in the washer used for the top, use the bolt and washers to clamp the broke piece into position, then through the notch drill a small hole that is the size of a small machine screw (6-32?or so)---tap the hole for threads, put in screw till it bottoms, cut off flush, move washer and put in another screw -----there would be no need to have a perfect seal, any slight leakage would just go into the valve chamber
Old 03-11-2016, 08:51 AM   #25
12secvx
I will try to take the pan off today and see what the actual state Babbitts look like and then I guess that will probably gauge how much should get into the repair. It does look like it has been through a fairly hard life. There is just no way of telling from the outside how good a used a motor really is. Which is why I took it apart in the first place. I had a bunch of spare parts and gaskets laying around and was planning on making a decent running motor to use this summer then store as a back up. I have a C head and rebuilt water pump for it as well as a B cam with good used lifters. I will post some pics when I get it apart.
12secvx is offline   Reply With Quote
Old 03-11-2016, 10:47 AM   #26
1955cj5
1955cj5's Avatar
Take it slow, take pictures, and ask questions!
Books are always recommended. This is a good place to start..
http://parts.modelastore.com/show_Product.asp?ID=6046
And Bert's has lots of used original parts if you need anything...
The oil pump will drop out when you take the pan off, and if the engine hasn't been upside down on a stand there will be about a quart of oil in the dip tray, even if the pan is empty...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 03-11-2016, 06:08 PM   #27
Tinbasher
Tinbasher's Avatar
Yes use the adhesive to bond the pieces back in place. Light years ahead of JB weld.
John Poole
Tinbasher is offline   Reply With Quote
Old 03-11-2016, 07:37 PM   #28
12secvx
I got the block apart at work today the main Babbitts look decent they have a couple cracks on in the #1 main on the block side and one on the rear main on the cap but it is on the inside thrust toward the #1 Cyl. All the rods looked good also.
Old 03-11-2016, 08:42 PM   #29
Rowdy
I hope you did not take my statement on finding someone to help adjust the bearings the wrong way. Seen people really destroy a good engine by not knowing what they were doing when adjusting. Not rocket science, but certain things matter when this is done. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 03-11-2016, 08:53 PM   #30
12secvx
I actually manage to make a living as Toyota Master Tech. So though I was a bonehead and rushed and ended up cracking the block. I'm actually very knowledgeable and have the tools and know how to rebuild and check the bearing oil clearance. But like most people if you aren't a 100% positive ask questions. I enjoy working on my model A though it is relaxing. And a huge change from working on Prius and Camry engines everyday.
Old 03-11-2016, 08:56 PM   #31
12secvx
Center Main
Old 03-11-2016, 08:57 PM   #32
12secvx
And rear main
Old 03-11-2016, 08:58 PM   #33
12secvx
And I found a bonus of sorts in it a aluminum cam Gear.
Old 03-11-2016, 11:13 PM   #34
tbirdtbird
" one on the rear main on the cap but it is on the inside thrust toward the #1 Cyl."
would you mean the #4 cyl?
the crack shows in the last pic.
It seems the thrusts always give out before the actual journal bearing goes south
'31 180A
tbirdtbird is offline   Reply With Quote
Old 03-12-2016, 12:20 AM   #35
12secvx
Yeah, that was a horrible description sorry about that and thanks for clearing it up. I agree it isn't the best area to have a crack but I think if I just adjust the oil clearance with the shims I can still get a summer or more out of it and hopefully not have a horrible rear main leak. I plan on cleaning out the rear main oil drain tube and passage good prior to reassemble.
Old 03-12-2016, 12:40 AM   #36
Gerald1961
Gerald1961's Avatar
Please consider that glues like JB weld need layers of at least 30-100 microns to harden correctly giving them the high tensile strength. This means putting the cracked parts together will change their dimensions slightly when glue is in between.
To avoid this you could dremel a bead for the glue into the cracked pieces. If you cant do this, you should consider machining the bore after curing.
Gerald1961 is offline   Reply With Quote
