Old 03-10-2016, 09:09 PM   #1
12secvx
Default Oh No! Now how am I going to fix this!
Long story short I was disassembling a good used running 30 A motor to reseal and do a cheap freshen up and use while waiting for my other motor to get done at the machine shop. And I was knocking the drive gear pin out with a drift punch and somehow busted a chunk out of the block!!! I was upset but now that I calmed down I'm thinking of ways to easily fix it. I thought I would ask your opinions. I do have the pieces that broke off.
12secvx is offline   Reply With Quote
Old 03-10-2016, 09:10 PM   #2
12secvx
Default Re: Oh No! Now how am I going to fix this!
And this one too
Old 03-10-2016, 09:47 PM   #3
12secvx
Yes it is a model A engine. And the drive pin I was trying to remove was the one that hold the top thrust collar on the oil pump/camshaft drive gear. I feel silly enough and guess I should of just figured it out on my own thanks.
Old 03-10-2016, 09:47 PM   #4
Rowdy
Vince, I beleive he is referring to the distributor drive and we are looking down at the top of the oil pump shaft in the second picture. I am not sure how you would break this while trying to reseal an engine. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 03-10-2016, 09:57 PM   #5
12secvx
The drive gear was very worn and I thought I would replace it with a new one that I had. I then found I couldn't remove it unless I removed the upper collar. I didn't want to scrap a good block with good Babbitts if I could save it some how. Sorry for the poor description but rod is correct about the area that is damaged in the pictures.
Old 03-10-2016, 10:00 PM   #6
12secvx
Fill it with Magna Steel and take my chances are my thoughts.
Old 03-10-2016, 10:02 PM   #7
Big hammer
Is that inside the valve chamber? Picture taken with a phone
Old 03-10-2016, 10:04 PM   #8
1955cj5
1955cj5's Avatar
If it makes you feel any better based on the crud in the center main oil tube that engine was not long for this world anyway...
To bad you broke the block.
You already learned that the drive gear assembly comes out easily and then you drive the pin out, if needed....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 03-10-2016, 10:11 PM   #9
12secvx
I probably pushed most of the crud in the tube trying to get the drive gear out.
Old 03-10-2016, 10:14 PM   #10
Russ/40
Russ/40's Avatar
I dont think its a problem. Probably wont hurt a thing.
Russ/40 is offline   Reply With Quote
Old 03-10-2016, 10:20 PM   #11
12secvx
I guess I'm not to worried about the drive gear housing walking around as much as I'm worried that it may effect the oil pressure going to the timing gear area.
Old 03-10-2016, 10:37 PM   #12
1955cj5
1955cj5's Avatar
I think if I were you I'd continue with the original plan for now.
But maybe not spend a lot on parts just yet..
Continue to disassemble and inspect and see what you find.
If there are no other serious problems you or someone else might come up with an idea to repair what you have....just thinking out loud but maybe you could turn down the drive housing and insert some sort of shouldered bushing in the block..
Old 03-10-2016, 10:43 PM   #13
Tinbasher
Tinbasher's Avatar
I'd clean it up and use a good two part structural adhesive. It's good to 800 deg. f. and has the strength of a weld. (80,000psi) 3M makes a good one.
John Poole
Tinbasher is offline   Reply With Quote
Old 03-10-2016, 10:47 PM   #14
12secvx
That is a idea then I could install some kind of indexing pin to keep the hole in the bushing lined up with the oil outlet. Thanks for you thoughts that is the reason I posted my issue in the first place.
Old 03-10-2016, 10:50 PM   #15
12secvx
John Poole
Are you suggesting using the adhesive to glue the broken off pieces back in place or to fill the void?
Old 03-10-2016, 10:54 PM   #16
KMeredith87
KMeredith87's Avatar
I think the shoulder bushing it a great idea as well...another thing speaking out loud...my brother in law own his own speed shop and I know for a fact one of his race engines had an intake that was repaired using JB Weld. I know a lot of people hate that stuff but it works pretty well when missed right. Not sure the temp that it holds up to but you may be able to build up that area using some JB Weld and then file and sand it to fit. Now vibration may be an issue that could break it up...who knows...just another thought...maybe build it up with a metal such as lead...
KMeredith87 is offline   Reply With Quote
Old 03-10-2016, 11:22 PM   #17
larrys40
I'm not going to beat you up but you obviously know as vince said you don't remove the shaft that way... The valve chamber and oil galley looks extremely dirty..., so before any attempt at any fix is made the block/valve chamber needs to be clean. If the crank is in it unfortunately there's enough crud in the main tubes from the valve chamber that you've already got the problem of pushing crud into the mains. A recipe for main destruction if not already happened. Also, keep in mind that the oil pumps up through the tube to the front of the valve chamber, filling the front chamber before spilling over to the center and rear chambers. The lack of the proper thrust ( pieces broken) may not allow sufficient flow up the tube to the front.. so it is best to attempt to make it whole. As John said maybe there's a better construction type adhesive that may work better but I do not know what that is.
As John said in post #15 you probably have one effort to try for a best effort fix.... and my suggestion would be to use jb weld with the area around it absolutely oil free and clean, then use the jb weld between the broken pieces to try and keep the thrust surface in tact, using the jub weld as a bonding agent/glue between the pieces and around the back side once they are in to reinforce it. At least it's in the valve chamber area instead of the lower end. make sure its a smooth clean path where the assemble fits in. I once used JB weld to glue together a pot metal fan support that held a 2-blade large prop fan 40 lbs in weight up... it held for 15 years.
Hopefully you've figured out the drive gear. I suspect it really didn't need to be messed with in the beginning. From the lack of cotter pin on the mains ( an inatentiveness on the last mechanic to touch it) and the dirt in the engine it probably isn't far from scrap with the damage. I certainly would NOT rebuild this engine as it is not worth pouring any significant funds into any more than the cost of a gasket kit. Just giving you my honest opinion and what I would do if it was to continue to be a running engine on a best effort basis.
hoping for the best!
Larry Shepard
larrys40 is offline   Reply With Quote
Old 03-11-2016, 12:41 AM   #18
Rowdy
As mentioned by others JB Weld or another quality adhesive is your only real hope. I would for sure at this point pull out the crankshaft and clean the oil passages and the rest of the engine inspect for other damage and re-assemble checking bearing clearances. If you do not know how to check and adjust bearings please get some help from a local club member that does know how. Just my thoughts it will never be perfect, but may live until you get your other engine back. Rod
Old 03-11-2016, 12:49 AM   #19
Russ/40
Russ/40's Avatar
There is so much spring tension there, I think there is enough shoulder to be stable without the repair.
Old 03-11-2016, 12:51 AM   #20
CWPASADENA
CWPASADENA's Avatar
I also agree with those who suggested J-B Weld.
As previously stated, everything must be absolutely CLEAN and oil free. I have used it many times in engines with very good results.
Chris W.
CWPASADENA is offline   Reply With Quote
