01-01-1970, 12:00 AM | #1 |
Guest
Posts: n/a
Re: 1979 351 M Lacks Power, Missed and Surges
Ignition module maybe failing <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #2 |
Guest
Posts: n/a
about how long do they last usually a new one was put on about 2 maybe 3 years ago. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #3 |
Guest
Posts: n/a
Have you recently washed your motor or has it sat out in the rain ?? Check your distributor cap for condensation on the inside. Module SHOULD last a lifetime BUT have had them bad from the factory. Also the same with the module in the distributor. Good Luck RW <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #4 |
Guest
Posts: n/a
Have you checked the fuel filter and checked all vacuum hoses? How about the tank and line, any sediment or possibility of a partially plugged line? <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #5 |
Guest
Posts: n/a
When your find the cure would you post the info for those of us[me for one]running the same engine,thanks <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #6 |
Guest
Posts: n/a
the engine hasn't been washed or been out in the rain lately and i didn't see any condensation under the cap <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #7 |
Guest
Posts: n/a
i thought i had it fix with changing the coil but after five miles it was back to the same problems again. A carburator rebuild kit seems to have fix the problem...at least it made it running longer than five miles. so i will have to see. i would like to thank everyone for the suggestions. d <table><tr><td><font face="arial"> |
