Old 07-07-2014, 06:45 PM   #1
farmputzer
Default Lub on window crank mech
Should there be lubrication in the window crank mechanism, specifically the little cup and spring that hold the window in whatever position you leave it? If lub is recommended, what type?
farmputzer is offline   Reply With Quote
Old 07-07-2014, 06:53 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Lub on window crank mech
I just lubed mine with white lithium grease and boy did it make a difference.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 07-07-2014, 07:10 PM   #3
Mitch//pa
i dont really use white lithium on anything anymore, thats old school. it dries up to easily and becomes ineffective. for brakes and things i use synthetic greases but to answer your question a good product for the window regulator is garage door track and chain lube available at Home Depot or lowes.
Old 07-07-2014, 07:15 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with Mitch about the white lithium grease and quit using it over 10 years ago.
I use Mystik JT-6 High Temp for almost everything that I grease.
I bought a tube of door lube in a round stick, and that made my Studebaker doors close much better. It might be bees wax, I'm not sure, but it's great for latches and won't grease your clothing.
Old 07-07-2014, 09:55 PM   #5
farmputzer
So are you saying the cup and spring should be lubricated?
Old 07-07-2014, 10:16 PM   #6
Tom Wesenberg
If it moves, I lube it. There is a spring lock inside the cup and I doubt you will get grease inside it, but oil will probably work it's way in. Whether this will defeat the purpose of the locking spring, I can not say. The locking spring is to hold the window in place until the handle is moved and releases the spring tension a little.
Old 07-07-2014, 10:19 PM   #7
Mitch//pa
the main things i lube is the roller track on the window and the regulator teeth.
Old 07-07-2014, 10:22 PM   #8
Tom Wesenberg
That's basically what I lube also. If the window glass is tight in the channel I might spray silicone in the side channels.
Old 07-07-2014, 10:25 PM   #9
Mitch//pa
yepper i always spray silicone also on the runs
Old 07-08-2014, 10:53 AM   #10
Quigley1930
Quigley1930's Avatar
My wife could hardly raise the window in my coupe. After greasing the track and gears works like a charm. As Tom says if it moves grease it!
Sewall Tyler
Quigley1930 is offline   Reply With Quote
