Old 05-13-2010, 12:14 PM   #1
Bruce_MO
Default Straw pinstripe paint source?
I need to pinstripe my '30 tudor...chicle & copra drab with a "straw" stripe. The standard 1-shot paint colors look too yellow in the on-line chips I've seen. I'm not sure if I can get my pinstriper to mix up something that looks pale yellow. I've looked at another pinstripe/lettering paint brand and they have a few colors that look closer to a pale yellow, but I'm having to look at on-line chips that could be way off.
Is there a ready source for the "straw" pinstripe shade? Thanks
Bruce_MO is offline   Reply With Quote
Old 05-13-2010, 02:55 PM   #2
bobpo
bobpo's Avatar
Default Re: Straw pinstripe paint source?
I've been striping for over 50 years. I'd stick with the One-Shot and if it's too yellow, try some ivory in it. It has been the pinstripers paint of choice for many decades. If you want more gloss and a harder paint, add about 15% automotive hardener to the one-shot. Most stripers don't know that it will mix, but it does. Shortens the workable life of the paint however. THIS WORKS.........Good Luck
bobpo is offline   Reply With Quote
Old 05-13-2010, 06:11 PM   #3
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I mix a little white one shot with the yellow until it comes close to the color chip and save that mix in a small bottle marked "straw".
Barry B./ Ma. is offline   Reply With Quote
Old 05-13-2010, 09:11 PM   #4
HOTRODPRIMER
HOTRODPRIMER's Avatar
I will agree with the others,,one shot is the way to go and most stripper don't mind mixing a little for a test pull,,HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
Old 05-14-2010, 01:01 PM   #5
Aerocraft
Aerocraft's Avatar
Oneshot has been my preference. Use the color chip from the Paint Guide book as published by the clubs and mix to match.
Aerocraft is offline   Reply With Quote
