05-07-2021, 08:52 PM | #81 |
Re: Anyone run a Lion Head
05-07-2021, 09:21 PM | #82 | |
Wow! Just think how much better that second engne would run without that cheap super restrictive air cleaner! |
05-07-2021, 09:25 PM | #83 |
05-07-2021, 10:35 PM | #84 |
40 Deluxe
I am sure that your cars drive amazing but the more I think about it the look is just a bit to modern for me. I know about the Snyder 5.5.1 and the 6.1 but does anyone else make a good stock looking high compression head? Thanks Ron |
05-07-2021, 10:40 PM | #85 | |
Email Tod to find out what he’s making these days. |
05-07-2021, 11:00 PM | #86 |
05-07-2021, 11:19 PM | #87 |
Here's his member page, you can send him an email. He makes the Snyder's heads and has been talking about doing stock heads in other CRs, so you should check with him to see what the status is on that.
https://www.fordbarn.com/forum/member.php?u=38974 |
05-07-2021, 11:32 PM | #88 | |
05-07-2021, 11:45 PM | #89 |
Tod Buttermore makes a 7:1 stock looking head, along with several others that don't look stock.
05-07-2021, 11:49 PM | #90 |
05-08-2021, 12:01 AM | #91 |
Is Tod Buttermore the same Tod that makes the Snyder Head?
05-08-2021, 12:03 AM | #92 |
Yes
05-08-2021, 12:27 AM | #93 |
05-08-2021, 05:47 AM | #94 |
05-08-2021, 06:54 AM | #95 |
Gene F, regarding harmonic dampeners, check your PM's.
05-08-2021, 07:24 AM | #96 |
I think we may be using different definitions of "stock." There's stock in the sense of indistinguishable from the factory part, and then there's stock in the sense of the proper aesthetic, something that looks "normal." You could make a 7:1 head look right to the untrained eye.
05-08-2021, 11:45 AM | #97 |
Tim Ayers, No web site, I can hardly manage e-mails!
05-08-2021, 12:05 PM | #98 |
Something to think about on compression. Picture this: You and your buddy both have '30 coupes, and are driving side-by-side down the road. His is totally stock, yours has an 8:1 head, twin 97's, modern ignition, touring cam, etc. Under the above circumstances, both are obviously using the same amount of power, as the speed and wind resistance are the same. So ... the cylinder pressure is the same on both engines, ergo, the higher compression has no detrimental affect on the engine. The difference is you are getting better fuel mileage because your engine is more efficient. So the question is, why are Model A guys afraid of compression???
05-09-2021, 03:58 PM | #99 | |
05-10-2021, 05:24 PM | #100 |
