04-14-2020, 11:40 AM | #21 |
Re: My first iron OHV casting!
Picked up some more cylinder head bullion today. 12 Winfield iron and the first OHV iron sample. They look very nice. Can't wait to machine the OHV. Winfield machining has already run parts.
Tod |
04-19-2020, 01:14 PM | #22 |
The rocker cover pattern for these new OHV heads. Finish pass CNC cut yesterday. Next is the inside.
Tod |
05-01-2020, 06:26 AM | #23 |
Tod, Gordon Eliot White's Leo Goossen Archives has copies of blue prints for both of the push rod heads, each penned by Goossen when at Miller and then at Schofield. I have those in my files. The Schofield print would permit you to verify exact water passageways/jackets, etc.
05-02-2020, 07:22 AM | #24 |
Wow the OHV casting looks great very interested to follow your progress
07-31-2020, 08:19 PM | #25 |
Any updates on the OHV, Tod?
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
07-31-2020, 08:35 PM | #26 |
I am mildly surprised that the combustion chamber is not hemispherical. I'm sure Tod will have considered it but I'd like to hear why he decided against doing it.
07-31-2020, 08:41 PM | #27 |
any updates on the blocks?
Lawrie |
08-01-2020, 08:24 AM | #28 | |
$US is dropping: |
08-01-2020, 10:43 AM | #29 |
The original Miller/Cragar's required A LOT of spark advance to develope good power, Dodgde's suggestion is very good. Also, the originals used 6 cyl. Buick rocker arms, 1.25:1 ratio. I would recommend 1.5's for several reasons, like, most performance cams are ground for 1.5:1 rockers, and valve lift is very important.
