12-22-2020, 08:13 AM | #1 |
Floorboard drawing for 1931 Ford with 1939 Transmission
Can someone post some pictures/drawings and measurements on the modified floorboard they made for the 1939 transmission tower in there 1931 Model A. Thanks |
12-22-2020, 12:03 PM | #2 |
Re: Floorboard drawing for 1931 Ford with 1939 Transmission
Make your own pattern in cardboard, test it, and then make one in plywood after you get the pattern right. Pretty simple job.
12-22-2020, 12:24 PM | #3 |
Thanks Russ
I know it is simple but like to see what people did do to it the right way. As I bought the floorboard that has the big battery opening to remove it. Merry Christmas |
12-24-2020, 12:42 PM | #4 |
Help! |
12-24-2020, 01:02 PM | #5 |
Hoop, I have a 39 tranny in my 29RPU. I can send you photos by weeks end, as well as a template for the steel plate. I also made my own mat which may interest you.
Stand by..... |
12-24-2020, 01:26 PM | #6 |
12-24-2020, 01:54 PM | #7 |
Hey Russ,
What did you use to make your mat? I have looked at some rubber mat material at Lowe’s that might work. I was thinking of making separate mats for the top and bottom boards so I can remove the bottom without having to remove the whole mat. The last time I removed it part of it cracked. David Serrano |
12-24-2020, 04:15 PM | #8 | |
https://www.snydersantiqueauto.com/P...earchByKeyword
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 12-24-2020 at 04:20 PM. |
12-25-2020, 01:06 AM | #9 | |
12-25-2020, 08:53 AM | #10 | |
To protect my carpet, I purchased a rubber door mat from Lowe’s and used the carpet as a template to cut the Lowe’s mat to match. It worked well. Sent from my iPhone using Tapatalk |
12-24-2020, 03:01 PM | #11 |
mine was made by upholstery shop. dark blue square weave carpet material and blue ribbed rubber mat i bought on internet (same ribbed pattern as running boards, but blue). Not much original about my 1929 cabriolet except for having a Model A four banger. |
12-24-2020, 06:13 PM | #12 |
Russ B,
Is that a Studebaker steering wheel?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
12-25-2020, 03:00 PM | #13 |
38 Stude center and spokes. I rolled a smaller diameter rim for it, welded it on, and Backwards Unlimited did the grip and rim color for me. The horn button is from a 34 Stude President. I made the outer column and welded the Studebaker shaft stub to the '56 Ford PU shaft. The steering wheel itself was quite a project to get, make, and adapt for what I wanted.
12-24-2020, 04:52 PM | #14 |
12-25-2020, 02:46 AM | #15 |
Ruth & Russ/40,
Thanks for the very helpful information, and Merry Christmas and a Happy New Year to you and all the Barners. David Serrano |
12-25-2020, 09:07 AM | #16 |
Thanks for hijacking my post this way it stays on top :-))) Merry Christmas |
12-25-2020, 11:15 AM | #17 |
Merry Christmas Joop...Frank Gemmell has a 39 transmission in his four door A that has traveled all over hell's half acre over the years. You might want to go take measurements from it...Ernie
12-28-2020, 02:45 PM | #18 |
Awaiting Russ/40 pictures and template. :-)))) |
12-29-2020, 12:30 AM | #19 |
Sorry, I'll do it tuesday.
12-29-2020, 04:05 PM | #20 |
Here are the photos. I can send hard copy paper templates with your self stamped envelope.
From my '29RPU with '39 transmission. |
