Old 08-20-2017, 10:40 AM   #1
Steve Plucker
Default What do you regret?
What is the worst thing that you did, and can admit to, to a Model A/AA, parts, body, whatever, that you regret doing and if you could do it all over again...you wouldnt?
My deal...I took apart about 4-5 steering columns (7-tooth) about 7 years ago...now I can not figure out what went to the original setups in the begining
Pluck
Old 08-20-2017, 10:44 AM   #2
Bill G
Bill G's Avatar
Default Re: What do you regret?
Being new to this, I haven't had much time to really screw up much, but I did one thing that is really a bummer. I tried to force off what I thought was a stubborn nut from the armature/ratchet of my Stewart Warner horn. So, I killed my ahooga.
Old 08-20-2017, 11:03 AM   #3
vern hodgson
Pluck
Took apart a dozen shocks in the early seventies. No idea what I was doing, put all pieces in five gallon buckets. There they sat, forever.
vern hodgson is offline   Reply With Quote
Old 08-20-2017, 11:17 AM   #4
Big hammer
When I painted my frame, rearend,front axle, etc painted them gloss black :-( With time it looks better, but still to shiny
get a bigger hammer tap done
Old 08-20-2017, 11:21 AM   #5
Railcarmover
Stuck a prybar in a water neck stud hole to loosen a head,broke the outside of the stud hole,since It wasn't in the water jacket I reassembled...then broke the upper neck torquing the head...fixed the head with belzona,buddy had a used neck, back running. I'm a field mechanic for a construction equipment dealer, I fix a shop mechanics error in front of the customer.It can be a tough situation, it costs all involved money.I go by two rules,always back a brother mechanic,and let the customer vent...then follow through with the comeback repair.
Railcarmover is offline   Reply With Quote
Old 08-20-2017, 11:28 AM   #6
Railcarmover
Old 08-20-2017, 11:34 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I REGRET that I got out of BED, today!
Bill WhereamI?
"THE ASSISTANT GURU OF STUFF"
Old 08-20-2017, 11:39 AM   #8
ursus
Took my short block to "the most reputable machine shop in the area". The shop foreman snickered about having to work on "that 'ol banger motor" and I still left it with him. I ended up paying a lot for what turned out to be the most shoddy work you can imagine. When I complained he just snickered something to the effect: " what did you expect me to do with an old engine like that?". Never again.
ursus is online now   Reply With Quote
Old 08-20-2017, 12:08 PM   #9
dmdeaton
Regret not getting into this hobby earlier in life
dmdeaton is offline   Reply With Quote
Old 08-20-2017, 03:25 PM   #10
Bill G
Bill G's Avatar
I share that regret!
Old 08-20-2017, 03:28 PM   #11
William Kelchner
William Kelchner's Avatar
Started it and tried to drive it.....
William Kelchner is offline   Reply With Quote
Old 08-20-2017, 12:30 PM   #12
TinCup
TinCup's Avatar
Pulling a stuck head and tearing my rotator cuff.
TinCup is offline   Reply With Quote
Old 08-20-2017, 01:14 PM   #13
Ray in La Mesa
Tried pounding out a stuck lifter, broke the lifter tower on a perfectly good block. It's amazing how quickly we realize (within seconds) we've done something stupid!
Ray in La Mesa is offline   Reply With Quote
Old 08-20-2017, 01:35 PM   #14
mike657894
mike657894's Avatar
threw out my vac wiper motor because it wasn't working. within the first few days of the resto. still shaking my head on that one.
mike657894 is offline   Reply With Quote
Old 08-20-2017, 01:56 PM   #15
2manycars
2manycars's Avatar
I took a pickup cab to the dump in 1970 because it was rusted at the bottom. An easy fix today, with all the repro parts.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 08-20-2017, 03:36 PM   #16
SSsssteamer
SSsssteamer's Avatar
I was told that the A motor that I had bought had recently been rebuilt. I rebuilt that A motor with all new valves, springs, guides, 0.040" over rings, etc. It didn't have a ring wear ridge in the cylinders so I assumed from what I was told by the seller, that the cylinder bore didn't have much wear and it was straight. So I didn't measure the cylinder taper. Wrong move... I found out when I started the engine up that the cylinders had too much taper and when cold, the pistons were slapping the walls. The block needed all four cylinders re-bored. What a waste of parts and time! Don't assume anything.
SSsssteamer is offline   Reply With Quote
Old 08-20-2017, 03:43 PM   #17
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Had a cracked head and took it to a machine shop in 1980, was charged $80 for stitching, Thats when you could get a good used head for $10. Live and learn.
Barry B./ Ma. is offline   Reply With Quote
Old 08-20-2017, 04:27 PM   #18
caboose
caboose's Avatar
Don't pry on a Model A fuel gauge for ANY REASON!
caboose is offline   Reply With Quote
Old 08-21-2017, 08:55 AM   #19
BILL WILLIAMSON
Good Morning, Barry,
I remember that being done, he drilled & tapped & screwed in cast iron plugs & snapped them off. FIRST, he dipped the threaded end in Sulphuric Acid, "maybe" as a thread locker???---Or as a RUST "starter" to plug up the crack????---Surely there was a METHOD TO HIS MADNESS???
Bill Watching
Old 08-20-2017, 04:34 PM   #20
BILL WILLIAMSON
I REGRET turning on the most STUPID, RIDICULOUS movie, the Dog "sed" "Lets watch it"---We DID---------
Bill W.
