Old 08-29-2012, 07:26 AM   #141
Vic Piano
Vic Piano's Avatar
Default Re: My new 1939 Sedan Delivery!
Lookin' good! I love the logo on the side.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 08-29-2012, 07:30 AM   #142
1937pickup
You can get more done on your cars while re-modeling than I do with nothing else on my plate.
1937pickup is offline   Reply With Quote
Old 08-29-2012, 07:40 AM   #143
SUHRsc
SUHRsc's Avatar
Thanks Vic...
'37.... I can't say that the remodeling is progressing as fast as it should be.... but.... have to keep my sanity by working in the garage too! haha...
-WANTED-
Pre-War Speed Equipment
Davies or Morrison Intake Manifold
77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads
SUHRsc is offline   Reply With Quote
Old 08-29-2012, 09:24 AM   #144
Bruce Lancaster
You are overcomplicating your life. Note the following two incontrovertible facts:
1. You cannot drive your house.
2. You can indeed live in a delivery car.
Case closed.
I do have a '39 Merc engine here...with a drop of paint on the "99" stamp it would be entirely indistinguishable from a 1939 85.
Bruce Lancaster is offline   Reply With Quote
Old 08-29-2012, 09:35 AM   #145
SUHRsc
SUHRsc's Avatar
Case closed.
You are absoltuely right Bruce....
I could give that '39 Merc motor a good "home" if its looking???
-WANTED-
Old 04-26-2013, 04:50 PM   #146
hemifalcon
So--I just found this site once again.. and found this thread--so what's new with this great looking delivery??
hemifalcon is offline   Reply With Quote
Old 06-04-2013, 07:51 AM   #147
SUHRsc
SUHRsc's Avatar
Finally a little update and some questions...
I have been sidetracked with many other things... and this poor '39 has been tucked in a corner...
A few days ago I rolled it out into the middle of the garage and started making some lists of parts I need and getting an idea of what REALLY needs fixed in order to get it on the road...
Mainly the drivers door is needing a good bit of repair... It had a rats nest in it and I guess that's what ate it from the inside out...
Luckily it only needs a little bit of repair to the inner structure and probably about 7 or 8 inches of the outside skin
Need to find some 19 gauge sheet to repair this... shouldn't be a huge undertaking, hopefully!
I tried to fit up the front splash panel that I bought, which was missing... seems its about an inch too short?
Is this possibly for another year or a deluxe?
I can make it fit, no problem... just wondering
I bought a running 59AB from a friend of mine a while back... Started fiddling with it to change some things to make it fit in the '39... going to use it for the time being. The old motor is on the stand above...
Trying to figure out what these extra wires are for? They were like this when I bought it... taped off... I don't see them in the wiring diagram?
Maybe I am just missing it?
This is the heater that was in there... seems like a nice instalation... would this be just a random dealer installed unit?
Still hunting another taillight stand... for the other side...
I bolted some fog lights on the front to see how they look... these say Studebaker on the lense... the age and wear seems to match the rest of this '39... had to remove the front license mount to attach them even on both sides.... I figure they will be good for turn signals as I'm planning to drive this quite a bit when it gets roadworthy....
So thats about it for now...
not going to be a fast process as funds are tight... but I would love to have this roadworthy for Hershey in the fall... we'll see!
-WANTED-
Old 06-04-2013, 08:10 AM   #148
Tim Ayers
Awesome! Thanks for the update and good luck on getting it to where you want it.
Old 06-04-2013, 08:20 AM   #149
SUHRsc
SUHRsc's Avatar
Thanks Tim!
-WANTED-
Old 06-04-2013, 08:58 AM   #150
Jason in TX
Jason in TX's Avatar
Looking good Zach. Love that delivery!
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 06-04-2013, 09:13 AM   #151
SUHRsc
SUHRsc's Avatar
Thanks Jason!
Also... still looking for a 2nd seat!!
-WANTED-
Old 06-05-2013, 05:44 AM   #152
SUHRsc
SUHRsc's Avatar
Didn't really have any time to work last night...
tried to figure out the door sheet metal thickness... seems right around .040-.042
Guess I'll have to get some 19 gauge to get something close.... shame I have 18 and 20 sitting around!
More interesting though...started trying to figure when this was built
The number from the transmission 5038238 looks like its between April 3rd and 28th
The list of running changes then seems to place it between May 17th and 26th
It has the newer type shocks on the back... but still has a slotted screw holding the door lock in as opposed to the hex...
-WANTED-
Old 06-05-2013, 08:18 AM   #153
LuckyFordGuy
LuckyFordGuy's Avatar
Great find love the pictures keep us posted Rog.
LuckyFordGuy is offline   Reply With Quote
Old 06-05-2013, 10:04 AM   #154
Bruce Lancaster
I think your dates line up nicely...the serial number date is when the engine was made at the rouge. Engines then were shipped off to the 20 or so assembly plants, and there installed in chassis.
I've never worried much about it, but sometimes instrument cluster and window glass are sources of dates more related to the whole car.
Exact timing was also affected by engines being stuffed into storage at each place and taken out probably in order of proximity to the door.
That 59 work??
Old 06-05-2013, 10:23 AM   #155
SUHRsc
SUHRsc's Avatar
I was glad all the dates made somewhat legitimate sense also...
The window glass is from '38... that's what I checked first...
Maybe something to do with the Sedan Deliveries being basically the same body from '38?
The 59AB turns over nice... haven't tried to fire it yet...
Thinking I should probably fix the brakes and wiring before I drop it in...
Any thoughts on those extra wires, Bruce?
-WANTED-
Old 06-05-2013, 10:28 AM   #156
Bruce Lancaster
None without some heavy research...but the parts manual drawings give some idea of basic routings of the bundles.
Where is your HL switch currently?? I think you have a car that had main swithc below steering but dimmer on floor. Might relate to that or to a modernized switch or maybe alien attack.
Old 06-05-2013, 10:34 AM   #157
SUHRsc
SUHRsc's Avatar
headlight switch is on the wheel and the dimmer on the floor... both are wired correctly and work as they should and also match the diagram in the little '39 booklet that has a ghost car drawing... which the drawing has no extra wires that I can see where these are located....
Horns had the correct wiring also, down below
Debating whether this wiring should be replaced or not... it does indeed work for the most part... and looks nice most places sealed into the car with layers and layers of solidified dirt and grime...
-WANTED-
Old 06-05-2013, 10:40 AM   #158
SUHRsc
SUHRsc's Avatar
Maybe Voltage Regulator? then it showed up with a cut-out?
The cowl has 2 screws in that area?
-WANTED-
Old 06-05-2013, 03:25 PM   #159
Chris
Chris's Avatar
Is there three screw holes on the firewall where there should be a voltage regulator?
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 06-06-2013, 09:59 AM   #160
SUHRsc
SUHRsc's Avatar
only 2 holes on the firewall....
but look at this
http://www.fordbarn.com/forum/showth...ght=kube+lunch
also... I noticed the wiring that went to the generator has tape on it like someone modified it...
-WANTED-
