09-28-2020, 03:54 PM | #1 |
40 Ford LED tailights
Wife says gotta update the taillights in my 40 coupe.She was following me last week on a bright sunny day and said she had to get within 15 feet to see my turn signals and brake lights. I've checked around for LED lights and BO Bob is out, Speedway has them but their bezel is plastic and Macs has them with a SS bezel. Has anyone had experience with Macs lights or is their a better solution? I dam sure don't want to get rear ended. Thanks
09-28-2020, 03:59 PM | #2 |
Re: 40 Ford LED tailights
6 volt or 12 volt. United Pacific in SoCal or Rodworx in Lakeland, Fl.should have the 12 volt variety.
Rodworx... https://www.rodworx.com/product-cate...40s-ford-leds/ Good Luck! Pat |
09-28-2020, 04:00 PM | #3 |
Another good idea, I think, is to add the 3rd brake light bar. The one that the center is the brake light and each end is a turn signal.
Speedway has them https://www.speedwaymotors.com/Speed...%20(Feb28_2020) No idea on the quality. Last edited by JSeery; 09-28-2020 at 04:09 PM. |
09-28-2020, 04:35 PM | #4 | |
09-28-2020, 07:12 PM | #5 |
Paint the inside of the light housing white and then slip a good flashlight reflector over the bulb socket. It will brighten those '40 lights right up and a lot cheaper than the LEDs.
09-28-2020, 07:38 PM | #6 |
09-28-2020, 07:41 PM | #7 |
White paint inside the housing. I also found 1156 6v LED light bulbs on superbrightleds.com and they really are super bright. They fit inside the tail lights on my pickup, but it looks like on their website, you can only get them in amber anymore. The white and red are discontinued. There are many other 1156 LEDs out there though, and you just swap the bulb.
https://www.superbrightleds.com/more...-car-bulb/511/
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35). |
09-28-2020, 08:36 PM | #8 |
About 20 years ago Lambert Enterprises had a booth at Nats South. I bought a LE card that mounted inside the tail light housing and used the stock lens and bezel. The lights were very visible. I see their kit is a little different now, but still use the LED card in the stock housing. I would recommend checking with them if you go to LED.
The '40 has an ideal mounting spot for a third brake light on top of the license plate. It puts it in the center of the car and at eye level. |
09-28-2020, 08:48 PM | #9 |
I got LED tail lights for my '41 from Ken Check and they are outstanding!. I get comments from every car guy who follows me.
Ken Check 541 653 8825 [email protected] |
09-28-2020, 09:25 PM | #10 |
Paint the buckets white. A 32 Ford headlight bulb will plug right into the socket. Gives you. Bright lights. The down side is that you’ll need to put a relay in the circuit to keep from burning out the brake switch on the back of the master cylinder
09-28-2020, 10:07 PM | #11 |
Check Julianos for LED glass taillights.
https://www.julianos.com/Tail-Lights-s/152.htm Also has them for the front. Be sure and let us know what you decide. |
09-29-2020, 06:16 AM | #12 |
09-29-2020, 07:31 AM | #13 |
Check out these lights I'm going to use from Technostalgia. They are high quality, properly fit the fenders, and a big improvement over bulbs.
1940 Ford complete taillight assembly including chrome plated bezels, buckets, lenses, and body seal. Includes two light assemblies with LED arrays, electrical harnesses, connectors, and attaching hardware. Our ’40 lights actually fit the fender. Lights designed to shine at towards the rear of the car, not at the sky. More Info... Installation Instructions Customer Pictures 6027 |
09-29-2020, 08:00 AM | #14 |
I ordered some Technostalgia taillights last night.
09-29-2020, 08:17 AM | #15 |
I vote for the 3rd brake light. I made this one for my '39. |
09-29-2020, 11:42 AM | #16 |
I use this third brake light in my 1936 6 volt and it works great also supports blinkers.
https://www.brakelighter.com/category-s/100.htm |
10-03-2020, 10:49 AM | #17 |
Got my Technostalgia 40 lights today. Very high quality.
10-03-2020, 11:04 AM | #18 |
Keep us posted on how they work out!
10-04-2020, 12:33 PM | #19 |
I have a '40 Coupe also. Would like to hear your wife's opinion of the Techno lights after you get them installed. I have LED tailights now, not too impressed with brightness. Have the third light on my tag with LED's and it is very bright. Thanks!
10-04-2020, 01:48 PM | #20 |
Good on you Gary buying decent LED . Painting the inside white and adding tinfoil in reality dont cut it as far as a decent LED. If you are worried about an LED not looking traditional , dont, you should be more worried about getting rear ended .
