Old 06-26-2020, 03:43 PM   #1
jdpalmer
jdpalmer's Avatar
Default Hinge bolt removal
Best way to remove slotted head Hinge screws in 29 roadster
Jimmy Palmer
jdpalmer is offline   Reply With Quote
Old 06-26-2020, 04:29 PM   #2
JoeCB
JoeCB's Avatar
Default Re: Hinge bolt removal
For tight screws in general the best tool that I have found is the hand held impact driver with a driver bit to CORRECTLY fit the screw head. This tool imparts a loosening torque and linear force simultaneously.
Joe B
JoeCB is offline   Reply With Quote
Old 06-26-2020, 04:52 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by joecb View Post
for tight screws in general the best tool that i have found is the hand held impact driver with a driver bit to correctly fit the screw head. This tool imparts a loosening torque and linear force simultaneously.
Joe b
I agree! An impact driver is often an overlooked tool.
Old 06-26-2020, 05:41 PM   #4
Oldbluoval
Oldbluoval's Avatar
Are you speaking of a removal that is trying to maintain paint etc
Or, will you be repainting etc?
If the former, heat and kroil will do wonders
Oldbluoval is offline   Reply With Quote
Old 07-07-2020, 09:34 PM   #5
jdpalmer
jdpalmer's Avatar
I got it with the impact tool and lot of soaking
Jimmy Palmer
Old 07-08-2020, 08:36 AM   #6
Jack Shaft
Used a square shank screwdriver with a crescent wrench..went back together with never seize on the threads.
Jack Shaft is offline   Reply With Quote
Old 07-08-2020, 09:08 AM   #7
Purdy Swoft
Purdy Swoft's Avatar
I usually need to heat them red hot first .
Old 07-08-2020, 10:19 AM   #8
Ruth
Good going!
Ruth
