Old 04-12-2020, 06:28 PM   #1
Mabel1930
Default Radiator shroud fit question
Has anyone had experience with installing the ‘28 shroud (original) with a reproduction radiator? The radiator in my 28 appears to be the low price version available from Mac’s. I’ve done a bunch of measuring and looks like the bottom tabs on the radiator are in the way- I’m curious if the tabs on an original or a Brassworks show quality radiator are in a different spot or orientation?
Thanks!
Mabel1930 is offline   Reply With Quote
Old 04-12-2020, 06:36 PM   #2
Vern
Vern's Avatar
Default Re: Radiator shroud fit question
It’s been a while, but it was difficult aligning the shroud tabs on my radiator. I don’t know what brand the radiator is, but I gave up in the end and used black zip ties at the bottom.
Vern is offline   Reply With Quote
Old 04-12-2020, 07:32 PM   #3
dlfrisch
dlfrisch's Avatar
The radiator had been replaced on my ‘28 Sport Coupe. I bought a new outer shroud. I had to trim (cut) the lower section a little bit adjusting it to fit in further- closer to the radiator, grind a small piece of each side of the lower radiator brackets and redrill the four mounting bolt holes. I still have not permanently mounted it back on again - I’m doing a complete body off. Things have pretty much stopped right now.
Dave
dlfrisch is offline   Reply With Quote
Old 04-12-2020, 07:39 PM   #4
dlfrisch
dlfrisch's Avatar
Opps... l was refusing to the outer radiator chrome cover.
Old 05-05-2020, 02:12 PM   #5
The Brassworks
The Brassworks's Avatar
The Brassworks uses and OE shell for test fitment on the 28. If you have a shell and would like it test fit to the radiator being built you would need to ship it in. It can travel back in the same box as the radiator
The Brassworks is offline   Reply With Quote
