Old 08-20-2018, 04:01 AM   #1
Ford1930
Ford1930's Avatar
Default How to attach a Turn Signal Flasher
I would like to read your views and experiences about the place and the way to attach the 6 Volt Turn Signal Flasher(3 Sprong Type) from Mac's. It has no mounting.
Ford1930 is offline   Reply With Quote
Old 08-20-2018, 05:25 AM   #2
springerpete
springerpete's Avatar
Default Re: How to attach a Turn Signal Flasher
I used zip ties and fastened to whatever was handy. Been secure now for many years.
springerpete is offline   Reply With Quote
Old 08-20-2018, 08:25 AM   #3
Ray64
Ray64's Avatar
what springer pete sez
Ray64 is offline   Reply With Quote
Old 08-20-2018, 09:14 AM   #4
Jerry in Shasta
Jerry in Shasta's Avatar
I used one of those spring broom hangers bolted the worked for me.
JB
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 08-20-2018, 09:19 AM   #5
BillEbob
BillEbob's Avatar
I used a worm gear hose clamp attached to steering column behind timing lever.
BillEbob is offline   Reply With Quote
Old 08-20-2018, 09:47 AM   #6
katy
katy's Avatar
This works:
Old 08-20-2018, 02:54 PM   #7
Gold Digger
I have used black tape and rapped it up on the top side of steering Colum.
Gold Digger is offline   Reply With Quote
Old 08-20-2018, 05:59 PM   #8
Fred K-OR
Fred K-OR's Avatar
I did the same except I used white tape.
One thing I did was to get one of the flasher blinker things that makes a noise to let me know it was on. Problem with the one I got, it sounds like a big rig backing up-to loud.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 08-21-2018, 05:52 PM   #9
Synchro909
Synchro909's Avatar
I just let the flasher relay hang on the wires in a somewhat out of the way place. They weigh next to nothing. Never had a problem.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 08-21-2018, 10:27 PM   #10
30Murray
I used a plastic 35mm film canister screwed to the firewall. The flasher slips inside it perfectly. This was before digital cameras were the norm, but you still might be able to find one in a camera or photo finishing store.
30Murray is offline   Reply With Quote
Old 08-22-2018, 04:02 PM   #11
eagle
eagle's Avatar
Just tape over the hole that the sound comes out of. More or less covering the hole, volume control!
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 08-22-2018, 04:06 PM   #12
Charlie Stephens
I just leave the turn signal flasher hanging from the wires.
Charlie Stephens
Old 08-22-2018, 05:52 PM   #13
Fred K-OR
Fred K-OR's Avatar
Good idea. I will have to try that.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 08-22-2018, 07:04 PM   #14
1931 flamingo
1931 flamingo's Avatar
I've got an electrical strip with all the wires to front and rear mounted to a magnetic strip with the flasher hanging behind the left kick panel. No seeie,
Paul in CT
Old 09-15-2018, 10:50 PM   #15
28Ca8149
My signal control has it’s own mounting that clamps on the column .This one has a small wheel that will cancel the switch when the wheel is turned back
28Ca8149 is offline   Reply With Quote
Old 09-16-2018, 10:39 AM   #16
Ed Wendell
Ed Wendell's Avatar
I used a Cole Hersee #3032-8x socket. It has a mounting ear and pigtails.
Ed
Ed Wendell is offline   Reply With Quote
Old 11-30-2018, 09:54 PM   #17
sofield
Velcro
sofield is offline   Reply With Quote
Old 12-01-2018, 09:33 AM   #18
Corley
Since I am 12volt, I used a motorcycle flasher, which looks like one of those small square relays, and has a screw tab for mounting. It is electronic, so works well with LED lites. No 3rd leg for an indicator light though, but since I have separate indicator tell tale lights for each side, I did not need the 3rd leg. If needed, a couple tiny diodes would create a 3rd leg.
Corley
Subscribed to the KISS principle!
Corley is offline   Reply With Quote
Old 12-01-2018, 12:16 PM   #19
whirnot
whirnot's Avatar
Originally Posted by katy View Post
This works:
That's what I use, attached behind floorboards,in the corner by the steering column. Can't be seen inside or out. so
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 12-01-2018, 03:55 PM   #20
LEM
LEM's Avatar
I installed the E-lights wireless directional intention lights from Egypt Garage. Works great without any wires nor flasher mounting.
www.theegyptgarage.com 585-598-6060
LEM is offline   Reply With Quote
