Old 06-28-2013, 02:49 PM   #1
Ronnieroadster
Ronnieroadster's Avatar
Default !953 F-1 Pickup Oil Pan Difference
Would anyone know if a center sump oil pan on a flathead V-8 fit in a 1953 Ford F-1 without hitting anything? Usually the rear sump pan with the removable lower plate to clean the oil pump screen is used in the F-1 from 1948 to 1952 but with the change in the 53 truck design the oil pan I think is different.
Thanks Ron
Ronnieroadster is offline   Reply With Quote
Old 06-28-2013, 05:17 PM   #2
Ross F-1
Ross F-1's Avatar
Default Re: !953 F-1 Pickup Oil Pan Difference
My parts book lists the same pan for 48 - 53 trucks. Kind of surprising, really.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 06-28-2013, 06:57 PM   #3
B_man_Al
B_man_Al's Avatar
I put an 8BA from a 53 ford car into my 48 F1...... Lots of room
B_man_Al is offline   Reply With Quote
Old 06-28-2013, 07:18 PM   #4
Ronnieroadster
Thanks for the pictures Al that's the same oil pan on the motor I built if the 53 has similar clearance there should be no problem at all.
Ross I'm surprised the parts book lists the same pan for 48 to 53 but you never know
Ronnieroadster
