Old 09-29-2020, 05:56 AM   #21
Bruce of MN
Bruce of MN's Avatar
Default Re: Distributor Removal Tip Re Ignition Cable Clamp
If they have to order it, ask what the freight charges will be; if high, see what they can do to reduce.
Old 09-29-2020, 10:24 AM   #22
shew01
shew01's Avatar
Originally Posted by Bob-A View Post
I kind'a did the opposite of what Bob Bidonde did and didn't have to remove the clamp either. I cut a portion off the top of the clamp just enough so the ignition cable kind'a, sort'a "clips" into the clamp.
Bob-A
This is interesting. Can you post a picture or two?
Old 09-29-2020, 04:36 PM   #23
shew01
shew01's Avatar
Originally Posted by Bruce of MN View Post
https://www.fastenal.com/products/details/0169548
1330 Courtland Road NE
Roanoke, VA
Thanks again. Fastenal didn’t have them in stock, but they ordered me a couple. They should be in on Thursday.
Old 09-29-2020, 05:38 PM   #24
Gold Digger
If my cars had a clamp like Bob's I would just bend it up till I changed things out and then bend it back down.
Gold Digger is offline   Reply With Quote
Old 09-30-2020, 05:48 PM   #25
Bob Bidonde
Bob Bidonde's Avatar
The cable is an anti-theft design, but I believe that thew clamp's purpose is to keep the cable from contacting the spark control rod.
Brent, I can change a distributor faster than you can change the points / condenser. You would also have to time the ignition. Changing the distributor does not require timing the ignition. Enough said. I rest my case!
Bob Bidonde
Old 09-30-2020, 07:44 PM   #26
Bruce of MN
Or setting the gap.
Old 10-01-2020, 07:54 PM   #27
CarlG
CarlG's Avatar
I think I got mine at Home Depot or Ace Hardware.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-01-2020, 07:55 PM   #28
CarlG
CarlG's Avatar
That would work, except for the fact that the original clamp had both halves secured by the #8 head nut.
Alaskan A's
Old 10-02-2020, 04:04 AM   #29
shew01
shew01's Avatar
Default Distributor Removal Tip Re Ignition Cable Clamp
The jam nuts came in. It fits like a champ. Thanks, Bob and Bruce, for posting.
