Old 04-12-2020, 10:32 AM   #201
Kube
Kube's Avatar
Default Re: Interest in new restoration project thread?
Yikes! I kind of forgot about this thread. Things like "life" got in the way I suppose.
Here's a little "catch up" on how this project is proceeding. Time to dedicate to it has been sparse recently. However, I have managed to get a number of things completed.
The dash, steering wheel, column, all window bezels, etc. are done.
Body has now had the second prime done and for the most part, it's blocked out. One more coat of prime, another block and wet sand should be enough.
Old 04-12-2020, 12:11 PM   #202
Hal Beatty
Hal Beatty's Avatar
Looks great! Thanks for the update.
Hal Beatty is offline   Reply With Quote
Old 04-12-2020, 02:51 PM   #203
jstrez5
Cant wait for you to start jim s.
jstrez5 is offline   Reply With Quote
Old 04-12-2020, 04:50 PM   #204
Old School Iron
For sure! That would be cool. Ready to learn! Thanks
Old School Iron is offline   Reply With Quote
Old 04-12-2020, 11:56 PM   #205
Mike Conshafter
Mike Conshafter's Avatar
This is the definition of perfection. What color are you going with Mike?
Mike Conshafter is offline   Reply With Quote
Old 04-13-2020, 01:22 AM   #206
V8COOPMAN
V8COOPMAN's Avatar
THIS...…..is the definition of "Perfection"! This is a convertible Mike did several years ago. This car since sold at a Sotheby's Auction for $165K....and you heard that correctly! This is the car that Mike now jokingly refers to as the one that was docked 1 point, which resulted in a score of 999 because of two tiny pits a judge found on one of the rear axle bells. Kubarth does some nice stuff, no? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-13-2020, 08:34 AM   #207
Kube
Kube's Avatar
Hey Mike,
This one will be Folkstone Gray. Black wall tires. Mohair interior.
Old 04-13-2020, 08:42 AM   #208
KGS
KGS's Avatar
Thumbs up Re: Interest in new restoration project thread?
Originally Posted by Kube View Post
Hey Mike,
Kube, Perfect color choice. Ken
KGS is offline   Reply With Quote
Old 04-13-2020, 01:13 PM   #209
RobR'35
RobR'35's Avatar
Incredibly nice!
RobR'35 is offline   Reply With Quote
Old 04-13-2020, 05:07 PM   #210
38bill
38bill's Avatar
Kube, do you keep track of the hours you spend on a restoration?
38bill is offline   Reply With Quote
Old 04-13-2020, 07:54 PM   #211
Kube
Kube's Avatar
Fairly well, yes.
Old 04-15-2020, 06:10 PM   #212
Kube
Kube's Avatar
Today is kind of exciting for me. Sprayed a light guide coat on yesterday and began the wet sand process today. Once I have the entire body sanded out, I'll do another guide coat and repeat the wet sand process.
I sand in four directions which ultimately provides a STRAIGHT body regardless of the angle one may look at it.
Old 04-15-2020, 07:30 PM   #213
V8COOPMAN
V8COOPMAN's Avatar
Kube….I'm gonna show my possible dumbness here, or at least some long-term memory loss, but do all '40s have that double "hole/slot" at every fender bolt location (as seen in your pic) or is that something you possibly dreamed-up to aid in perfectly aligning the fenders to the requisite "Kubarth Standard"? That's gonna be another "sweetie" straight out of Wisconsin. DD
T5 W/TORQUE TUBE
Old 04-15-2020, 08:34 PM   #214
STEVE O
STEVE O's Avatar
delete
STEVE O is offline   Reply With Quote
Old 04-15-2020, 09:13 PM   #215
deuce_roadster
deuce_roadster's Avatar
The nut for the rear fender bolt is on a special clip that is held by the rectangular hole, bolt goes through the round hole. I don't know if other years use this or not. 39 might. 40 is my newest old Ford.
Old 04-15-2020, 09:21 PM   #216
V8COOPMAN
V8COOPMAN's Avatar
Thanks Mike! I just didn't remember seeing that slot configuration in the past. Dick D
T5 W/TORQUE TUBE
Old 04-15-2020, 09:49 PM   #217
Mike Conshafter
I’m not going to argue that one...lol. Beyond impressive and worthy of a poster size print. Restorations of this level can justify an amount of that caliber. Talent is one thing, it’s when combined with a person that is detail oriented and the willingness to research for days on end that perfection shows. It’s the correct fastener finished correctly and installed in the correct direction.....and so on.
Old 04-15-2020, 10:00 PM   #218
Mike Conshafter
Hey Mike,
Man, you’re speaking my language. Gray tones with black walls are simple but tough and yet very striking. Ford had so many great darker colors throughout the 30’s and 40’s.
Old 04-15-2020, 10:18 PM   #219
GB SISSON
GB SISSON's Avatar
Like many others, I am in awe of your work. I hope to someday see your work in person.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 04-15-2020, 10:58 PM   #220
FlatheadTed
FlatheadTed's Avatar
Wow great work ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
