Old 11-19-2023, 11:49 AM   #1
bobsmanstuff
bobsmanstuff's Avatar
Default switch
my brake lights started to work sometimes and sometimes not. I did find a bad spot in the wire near the switch. I bought new pigtails to splice in. if it comes down to replacing the switch, would I have to bleed the the brakes.
Thanks
bobsmanstuff is offline   Reply With Quote
Old 11-19-2023, 11:56 AM   #2
29spcoupe
29spcoupe's Avatar
Default Re: switch
You can bleed the brakes if you wish. You should not have to if you replace the switch quickly.
29spcoupe is offline   Reply With Quote
Old 11-19-2023, 01:40 PM   #3
38 coupe
38 coupe's Avatar
Default Re: switch
I swap in a new brake light switch on my 53 sedan about once every two years due to the terrible quality of new switches. I have not had to bleed my brakes when swapping a brake light switch.
Old 11-19-2023, 03:27 PM   #4
bobsmanstuff
Default Re: switch
Thanks very much guys.
Old 11-19-2023, 05:56 PM   #5
29spcoupe
29spcoupe's Avatar
Default Re: switch
It may not be the switches. Silicone brake fluid will destroy the type of switch that screws into the master cylinder. This is why the switches were moved to the pedal.
Old 11-19-2023, 06:14 PM   #6
tubman
tubman's Avatar
Default Re: switch
Brake light switches are very suspect these days. If you read this whole thread, you will find that our own '39-'40 expert "Kube" encountered FOUR bad switches before he finally got a good one.
https://www.fordbarn.com/forum/showt...ighlight=brake
Old 11-19-2023, 07:13 PM   #7
bobsmanstuff
Default Re: switch
I had forgot to ask another question. When replacing the wires or switch does it matter witch wire goes to witch side of the switch?
Old 11-19-2023, 10:10 PM   #8
JayChicago
JayChicago's Avatar
Default Re: switch
Either way. Does not matter to a switch.
JayChicago is offline   Reply With Quote
Old 11-20-2023, 08:35 AM   #9
bobsmanstuff
Default Re: switch
Thank you
Old 11-20-2023, 10:01 AM   #10
nelsb01
nelsb01's Avatar
Default Re: switch
Once done replacing the switch, it is always a good idea to check the master cylinder level.
nelsb01 is offline   Reply With Quote
