Old 06-26-2013, 02:20 PM   #1
buddridge
Default Distributor Drive Gear
Hope I can change the distributor drive gear on my 30 Roadster without dropping oil pan. Can this be done after removal of the valve cover? Any info would be appreciated. Bud
buddridge is offline   Reply With Quote
Old 06-26-2013, 02:38 PM   #2
mantta
mantta's Avatar
Location: Keweenaw Bay, MI (Michigan's Upper Peninsula)
Default Re: Distributor Drive Gear
Yes, it will not come out through the bottom.
mantta is offline   Reply With Quote
Old 06-26-2013, 02:38 PM   #3
quickchange
quickchange's Avatar
Yes. remove dissy 1st, valve cover. ,spring, then it will lift up & out. You may need to retime the dissy after all back together, hope this helps,
quickchange is offline   Reply With Quote
Old 06-26-2013, 08:14 PM   #4
Joe K
Joe K's Avatar
And going back together can be a challenge to get that "prong" lined up with the oil pump. Just play around with it moving it a tooth at a time.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
