Old 03-16-2011, 03:04 PM   #1
Gumpy
Gumpy's Avatar
Default Frame model A serial numbers?
My friend just bought a frame with stamped numbers A0467968?
Can u tell what it was originally ? Thank you gump
Gumpy is offline   Reply With Quote
Old 03-16-2011, 03:07 PM   #2
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Re: Frame model A serial numbers?
The "0" is not correct??? what gives with that and are the stars there also,
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 03-16-2011, 03:30 PM   #3
Gumpy
Gumpy's Avatar
Smile Re: Frame model A serial numbers?
Try this number. A6467968 then star. Thank you
Old 03-16-2011, 03:45 PM   #4
msmaron
msmaron's Avatar
Too large of a number
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 03-16-2011, 03:58 PM   #5
IrishHills
IrishHills's Avatar
Frame # matched engine...
Engine #0467968 was made on Sep 27, 1928
http://www.modelahouse.com/cgi-bin/enumbers/numdate
IrishHills is offline   Reply With Quote
Old 03-16-2011, 03:58 PM   #6
Bob/Kansas City
Bob/Kansas City's Avatar
This is not a number that would relate to the Model A numbering sequence.
If the number is A467968 it would relate to an engine built on September 27th of 1928. It would have been one of 4392 engines built that day.
The frames were stamped with the engine number at the time of assembly.
Bob/Kansas City is offline   Reply With Quote
Old 03-16-2011, 04:21 PM   #7
Gumpy
Gumpy's Avatar
Ok thanks
Is the frame only stamped in one area ? Or multiple? Like 1940?
Old 03-16-2011, 04:37 PM   #8
Bob/Kansas City
The frames were only stamped on the top rail of the left side of the frame under the location of the cowl.
Old 03-16-2011, 06:20 PM   #9
msmaron
msmaron's Avatar
There would have been NO "0" in the number at all
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 03-16-2011, 07:24 PM   #10
Gumpy
Gumpy's Avatar
ok thanks Bob--- don't know much about A's......but here's a new number -----star A3467968 star------
just trying to help my old friend out!!!! thank you GUMPY
Old 03-16-2011, 07:32 PM   #11
Joop
Joop's Avatar
Engine #3467968 was made on May 23, 1930
Joop is offline   Reply With Quote
Old 03-16-2011, 07:33 PM   #12
Gumpy
Gumpy's Avatar
ok thanks joop
Old 03-16-2011, 10:41 PM   #13
SSsssteamer
SSsssteamer's Avatar
This is what our 1930 Phaeton's frame serial number looks like. The car came out of the Mohave desert so there wan't any rust hinding the frame number.
SSsssteamer is offline   Reply With Quote
Old 03-16-2011, 11:05 PM   #14
tiquer
How about this one LOL # is cap5275 1931 Canadian. this motor is for sale.
tiquer is offline   Reply With Quote
Old 09-28-2014, 08:33 PM   #15
David_modelA
So if my frame is stamped *2909353* that means that the engine had that serial Number? I am trying to find out what the body style was for the original vehicle. I believe the frame is 1928/29, but do not know if coupe, phaeton, truck or ???? I am new at this, so any help is appreciated.
David_modelA is offline   Reply With Quote
Old 09-28-2014, 08:56 PM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
The engine was stamped when completed, then the same number was stamped on the frame when the engine was installed, so it could be a few days or months later. The number is only a serial number and won't tell what body was original to the frame.
Old 09-28-2014, 09:10 PM   #17
pooch
pooch's Avatar
If you have two extra body mount holes where the rear of a pickup cab ends, and the holes look original, bit hard to discern if they were done on the assembly line after 85 years , but if you could, this would mean it was a pickup.
And vice versa, if there are no holes there, it means it definitely was not a pickup (from new ).
pooch is offline   Reply With Quote
Old 08-09-2017, 02:02 PM   #18
smithw3
Can you provide as much information as you can about frame number "AX2911751". I believe it was stamped in February 1930. Is that correct? What does the "AX" indicate? Thank you, Warren
[email protected]
smithw3 is offline   Reply With Quote
Old 08-09-2017, 05:13 PM   #19
Bob C
Here is another thread with an AX number. https://www.fordbarn.com/forum/showt...+engine+number
Bob
Old 08-10-2017, 10:30 AM   #20
wingski
wingski's Avatar
Hi, could you post a picture of the serial number from a little farther back so I can see exactly where I'm going to have to look for my A's serial number? Also, is it possible to see the number with the apron removed and the body lifted a couple of inches? Thanks.
wingski is offline   Reply With Quote
