05-27-2021, 06:30 PM | #1 |
PS idler arm
Hi all,
I have new bushings for my PS idler arm but the bushings that I took off had these cups. Do I need to keep them with the new bushings? They were the original bushings. Thanks, Mike
05-28-2021, 04:05 AM | #2 |
Re: PS idler arm
What are you working on?
***** - MULTI-VEHICLE SYNTHETIC TRANSMISSION FLUID - Multi-vehicle transmission fluids are becoming more and more popular in the marketplace. Oil marketers design these fluids for a wide range of automatic transmission types. While they are not licensed by any specific auto manufacturer ... ??? ... enough said ... DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
05-28-2021, 02:10 PM | #3 |
Re: PS idler arm
Sorry, 57 country sedan, v8 with PS.
Mike
05-28-2021, 06:24 PM | #4 |
Re: PS idler arm
Below is an ILL of OEM install (complete service kit). Those washers look like they are from a 3C590 kit (steering cyl bushing kit).
Did you just buy the bushings or a complete service kit?
05-28-2021, 09:02 PM | #5 |
Re: PS idler arm
Idler Arm for 1957 Ford Country Sedan needing Bushes. |
05-29-2021, 03:19 AM | #6 |
Re: PS idler arm
05-29-2021, 05:34 AM | #7 |
Re: PS idler arm
I just bought the bushings. I will look at the kit and see if I can get the washers as well.
Thanks, Mike
05-29-2021, 09:11 AM | #8 |
Re: PS idler arm
What you have may not be OEM but aftermarket.
There were so many vendors (and quality) over the years it would be hard to ID. Let us know what you find.
05-29-2021, 02:55 PM | #9 |
Re: PS idler arm
I think it is original do to the rust/ dirt on it. But then again it could have been replaced 50 years ago at some point. Either way I will put it back together with the washers.
Mike
05-29-2021, 05:25 PM | #10 |
Re: PS idler arm
Ok, so I think I have this thing mocked up correctly-I got lucky in that the bushings just dropped right onto it. I also noticed that the bushings were slightly off center with the inner sleeve, will that be a problem?
Mike
05-29-2021, 08:57 PM | #11 |
Re: PS idler arm
There is something about the arm itself and the take-off bushings that doesn't seem quite right.
Below are other ILL's showing ASSY and DETAIL. The washers have to be flat as to not interfere with inner/outer bushing sleeve movement. If you go ahead, make sure the concave washer does not interfere with the bushing(s) (turn upside down) and don't fully torque to spec until steering wheel is centered and toe can be set correctly.
05-29-2021, 11:02 PM | #12 |
Re: PS idler arm
The 1956 model year was the first time they switched to the encased rubber bushings on the idler arms.
The '54/55 cars with power steering had a very complex system incorporating a set of standoff/inserts at top and bottom of the steering arm or idler arm bracket. There was an accompanying large round roller bearing and flat-washers that sat on the standoff at each end. There was no need for a press. The standoffs were machined to fit snugly in the bore of the steering arm and idler arm bracket. Each roller bearing had a grease fitting. The problem with this arrangement was that no one ever greased the roller bearings, they dried out and started to cause hard steering. However, the design (if it had been properly maintained) was superior to the later encased rubber bushings. Once upon a time, Timken made replacement roller bearings, but the pattern was dropped when they started stamping in china, and no other bearing companies produce replacements for that pattern today. I had a complete original '57 PS setup which only had the metal encased rubber bushings with large flat-washer and castle-nut on the end. Flat-washers were only about 1/16" thick. |
05-29-2021, 11:09 PM | #13 |
Re: PS idler arm
A few years ago, you could buy the whole kit including idler arm, bushings, washers and castle-nuts. Now, some vendors are only selling the bushings.
If you had an earlier idler arm replacement from a kit, you may notice that the shaft portion is way smaller than the original, but they cast-in a couple of "gussets" at the base of the shaft to keep the shaft centered. Those gussets can wear-down and cause too much vertical slop in the idler arm movement. So if you can only get bushings now, it may not help if you had one of those aftermarket idler arms. |
05-30-2021, 05:54 AM | #14 | |
Re: PS idler arm
If you decide on a correct arm, you may find one on EvilBay - B4A 3352-B (PS) FORD NOS.
05-30-2021, 08:07 AM | #15 |
Re: PS idler arm
This keeps bothering me.
05-30-2021, 06:12 PM | #16 |
Re: PS idler arm
That second photo is a roller bearing kit for '54/55 (and would fit the '56 idler arm), but I don't think the old style was available at the factory anymore.
The original print of the '56 Ford Car shop manual shows metal encased rubber bushings for the PS idler arm. (that could mean that the early '56 cars might have had some of the '55 idler arm kits, but that the rubber bushings shown in the shop manual were the factory authorized replacement). What bothers me is that his '57 idler arm has large recessed washers on the shaft ends that have no value at all with the use of rubber bushings. I think that idler arm came off a different car. Mercury or Edsel maybe? |
05-30-2021, 06:55 PM | #17 |
Re: PS idler arm
Here is the bracket and large bushing that I knocked out. No bearings in it-just lots of rubber. I do have a relatively early early car-I think. It is numbered 156915 from Norfolk. From what I have read you drop the ‘1’ so that would mean it is #56915.
Mike
05-31-2021, 05:02 AM | #18 | |||
Re: PS idler arm
05-31-2021, 01:29 PM | #19 |
Re: PS idler arm
Thanks K,
This car is so banged up anything is possible. IT may have been rebuilt/replaced decades ago. But will start looking. Mike
05-31-2021, 06:16 PM | #20 |
Re: PS idler arm
After seeing your avatar photo, I was under the assumption it was a cherry piece. The parts are out there if you know where to look. I wouldn't trust anything new as to quality. Once you have the kit you can use those bushings for rebuild in the future.
