02-09-2019, 02:50 AM | #1 |
Headlight options for 6v
Since the regular type generators aren’t meant to handle the high amp of the newer halogen type lights , are there any lower amp 6v bulbs that put out a good amount of light ?
Or is there any place that sells old style lights or a good alternative?? |
02-09-2019, 05:16 AM | #2 |
Re: Headlight options for 6v
Some are turning to LED's which I am planning to do.Here is a link.
https://redirect.viglink.com/?format...bulbs-shop.php |
02-09-2019, 09:12 AM | #3 |
Got LEDs, turned the generator output right down on the third brush.
02-09-2019, 12:26 PM | #4 |
Thanks deuce lover , I ordered up a pair of their 6v bulbs . Exactly what I was looking for
03-13-2019, 10:05 PM | #5 |
Just got around to installing the lights that deucelover suggested. All I can say is WOW ��
These lights are so bright and produce such a crisp white light .visibility is so good , definitely exceeded my expectations . And they draw so much less amps that it works great with my 6v generator Thanks so much deuce lover , my car is a pleasure to drive at night now , and WAY safer from a visibility standpoint |
03-13-2019, 10:12 PM | #6 |
Thank you for following up! . |
03-13-2019, 10:35 PM | #7 |
Tinker I just purchased a house ,and I hadn’t even thought of them for it. I think after your suggestion I will switch the house over to LED lighting .
03-13-2019, 10:41 PM | #8 |
Don't get the blue light ones. Warm light versions are most like the incandescent light. Blue/white is like a florescent bulb. LEDs have come down a bunch and have high watt outputs, since 5 yrs ago. Cheap way to save a buck to spend on a ford.
Thanks to your thread and deuce, I saved that link. Brighter lights on 6v. Last edited by Tinker; 03-13-2019 at 10:55 PM. |
03-13-2019, 11:09 PM | #9 | |
Charlie Stephens |
03-14-2019, 01:03 AM | #10 |
Thanks for the input Charlie and Tinker ! I have a Costco nearby so that is a plus .Look forward to making the switch.
03-14-2019, 10:05 AM | #11 |
03-14-2019, 01:44 PM | #12 |
I didn't see a sealed beam light, do the make them also. Like for my 41? Al
03-14-2019, 04:49 PM | #13 |
So you'll never have to change them again Tink?
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
03-14-2019, 04:59 PM | #14 | |
Which LED bulbs to select to replace the dual filament headlight and taillight bulbs in a '34 Ford?
03-14-2019, 05:42 PM | #15 |
These LEDs are great but how do you convert an old Ford seal beam lamp to accommodate these bulbs?
03-14-2019, 08:14 PM | #16 |
You can get semi-sealed beams that take an H4 bulb and LED replacements are available for H4 bulbs at 100 british pounds ($180 NZ) they are not cheap.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
03-14-2019, 08:41 PM | #17 |
Home leds? 10yrs probably, 30 your guess is as good as mine. The early leds were made well. Who knows now. Heck we can put a man on the moon but you can't keep a bumper from falling off a 70s Cadillac. No money in letting it stay on. Have a porch light that's never turned off. going on 4 yrs now. . Last edited by Tinker; 03-14-2019 at 08:54 PM. |
03-15-2019, 10:30 AM | #18 |
03-15-2019, 10:43 AM | #19 |
Are these available with the front glass shaped like our originals and not flat which is an instant give away as not being original? I want to stick with an all original appearance. I put some Hellas on my RV and they are totally flat on the front glass.
03-15-2019, 01:00 PM | #20 | |
I've got Cibie on a couple of my cars. (7-inch, round, like 6012H used on most 50's, 60's cars) They are not flat, but rather, convex, shaped like originals. They take the H4-type bulb. I've had them around 30-40 years. But note, even though they have the original shape, they are still an instant giveaway, because the glass diffusion pattern is different, doesn't match original, at all. On the plus side, I think they are great, as they are substantially brighter than 6012H, and the light is 'focused', with a sharp cutoff at the top. (No stray light up in the trees) JMHO Looks to me like these Cibie's, with the 6V H4's that duecelover posted, would be a pretty good option for 40-55 cars. (I see Cibie on-line, at Walmart, Amazon, e-bay, and several other places.) (If you are looking on-line, check out VintageCarLED VCm35-7 inch kit. It's like Cibie, but the diffusion pattern is more like 6012H - ie, more like original. $209 pair) Last edited by bobH; 03-15-2019 at 01:30 PM. |
