Old 07-08-2012, 03:16 PM   #1
mike37cdn
Default 1951 ford conver overdrive trans removal
i have a 51conver with an overdrive trans can the trans be taken out with out taking out the motor because of the x frame tranny needs two come out oil leaks at the shafts on the tranny thanks
mike37cdn is offline   Reply With Quote
Old 07-08-2012, 03:49 PM   #2
Russ/40
Russ/40's Avatar
Default Re: 1951 ford conver overdrive trans removal
No need to remove engine or rear. The cross member comes out.
Russ/40 is offline   Reply With Quote
Old 07-08-2012, 04:22 PM   #3
52merc
52merc's Avatar
make sure you take the solenoid out before taking trans out
52merc is offline   Reply With Quote
Old 07-08-2012, 04:44 PM   #4
charles in east texas
charles in east texas's Avatar
Red face Re: 1951 ford conver overdrive trans removal
Have a rag handy to poke in the solenoid hole when you turn it 1/4 turn to take out. Also a good idea to replace the solenoid seal while you have the transmission out. Charles
charles in east texas is offline   Reply With Quote
