Old 11-29-2020, 06:51 PM   #1
russcc
Default '40 "resistance unit"
Where is the resistance unit as shown in the Ford '40 wiring diagram between the ignition switch and coil. Is that it high on the inside of the firewall on the driver's side ?. Looks like I am going to have to go back to 12 volts in the '40 as the 59L's compression is a little to stout for the 6 volt battery. In the roadster I run 12 volts, and bypassed the ignition ballast I installed as the coil has a built in resistor, and has worked great with the 21A distributor.
russcc is offline   Reply With Quote
Old 11-29-2020, 07:03 PM   #2
cadillac512
cadillac512's Avatar
Default Re: '40 "resistance unit"
Yep, up high on driver side (U.S.) right next to the lighting circuit breakers.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 11-29-2020, 10:04 PM   #3
JSeery
JSeery's Avatar
It is part 12250 on the wiring diagram. The circuit breaker and ballast resistor are mounted on the same board.
File Type: jpg Flathead_Electrical_wirediagram1940car.jpg (78.3 KB, 18 views)
Old 11-30-2020, 06:25 AM   #4
russcc
Thank you all.
