04-17-2020, 12:13 PM | #1 |
Frame tables, let’s see them.
Even though most on this site will be restoring a frame instead of building one, a frame table comes in very handy when replacing damaged sections or making welding repairs. This is what I built for a 32 frame, but it will work on many others.
Anyone else have one, or ideas for one? |
04-17-2020, 06:40 PM | #2 |
Re: Frame tables, let’s see them.
Had this for 24 years now . Very handy anda good parking spot most of the time .
04-17-2020, 07:12 PM | #3 |
That’s definitely a professional one!
04-18-2020, 09:44 AM | #4 |
I made mine such that I could rotate it to make all the fabrication and welding work a lot easier. This was one of the smartest decisions I made - really helped the complexities of the fabrication process, the boxing plate installs/welding, etc..
The end stands are made like engine stands (and I made them such that when I don't have the jig together, they are engine stands). I used the construction of the stands and the jig as my first TIG welding project (had done a lot of oxy-acet and stick before). The cross bars have adjustable frame holders - so they can be moved to handle any width/style of frame - the first being a custom 34 frame I built. Also, it comes all apart as I knew that I would not want it taking up room in my shop and it is too heavy to move if it is all together . . . anyway, here is my take on it. Rear2-cropped.jpg PSideRear-cropped.jpg PSideFront-cropped.jpg SlidingUpright1-cropped.jpg Rear1-cropped.jpg Last edited by Bored&Stroked; 04-18-2020 at 09:50 AM. |
04-18-2020, 09:52 AM | #5 |
Yours looks a lot like mine
04-18-2020, 10:11 AM | #6 |
I have 4 stands with it that are EXACTLY the same height and they allow you to check a frame with laser levels really quickly . The rotisserie feature on the third one would be really handy but mine is WAAAAY too heavy for that . |
04-18-2020, 01:00 PM | #7 |
Saw some pictures the other day; where a manual slack adjuster and brake cam shaft (truck air brakes) was used as a "rotary reduction gearbox on a frame jig. Looked like a slick set-up.
04-18-2020, 03:31 PM | #8 | |
I used mine fog pinching frame in as well. |
04-20-2020, 11:03 AM | #9 |
Nice work gents; some creative approaches!
04-20-2020, 11:43 AM | #10 |
I’m collecting a bunch of 5” channel iron from pallet racking in a warehouse. I may put something like this together......Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
04-20-2020, 12:13 PM | #11 |
This is what I made up using a old welding table for my current project. I really like the idea of the rotisserie table.
