03-21-2020, 11:37 AM | #1 |
1935 trunk support specs
Does anyone have the measurements on these? I don’t think anybody reproduces these and I would like to try and make some. I’m talking about the brace that goes from the floor pan up to the lip of the trunk on each side.
Thanks, Ralph Oops! I guess I should’ve said these are for a three window coupe. |
03-22-2020, 04:21 AM | #2 |
Re: 1935 trunk support specs
I don't have measurements, but here are some photos someone posted a while back.
03-22-2020, 11:27 AM | #3 |
Thank you Don!
That helps a lot, I guess I can estimate the width by the mounting holes. I also assume the dimpled area is where the tool tray mounts ? |
03-22-2020, 11:42 AM | #4 |
I also assume the dimpled area is where the tool tray mounts ? That,s my understanding!
03-22-2020, 06:12 PM | #5 |
So this is what it came with, always puzzled me why they moved the supports to right behind the rear of the top/ window.
Also used some screws through the body, which look ugly to me. |
03-28-2020, 04:37 PM | #6 |
I also have to take into consideration that the trunk surface is angled downward there for the support has a slight angle to it as well. Last edited by RalphM; 03-28-2020 at 07:04 PM. |
