Old 11-20-2017, 08:42 PM   #1
choptopjimmy
Default Reverse eye spring for stock shackles
Hello. I'm looking for a reverse eye front main spring that will have the correct sized eyes in order to work with the stock shackles and steel bushings. Does anyone know who might make these? Thanks, Jim
choptopjimmy is offline   Reply With Quote
Old 11-20-2017, 08:47 PM   #2
Licensed to kill
Licensed to kill's Avatar
Default Re: Reverse eye spring for stock shackles
Front or back?, I recurved my front mainspring myself to reverse the eyes. Pretty simple process if you have a press. You don't need much of a press to do it.
Licensed to kill is offline   Reply With Quote
Old 11-20-2017, 09:20 PM   #3
choptopjimmy
Sorry, I should have stated that. Front spring. I tried to recurve the stock one and it didn't work. That's why I'm looking for a new one. Thanks, Jim
Old 11-20-2017, 09:57 PM   #4
lindy williams
"A" Springs will make you one. He made a rear reversed eye main leaf for me.
lindy williams is offline   Reply With Quote
Old 11-20-2017, 10:21 PM   #5
klawockvet
klawockvet's Avatar
Posie super slider reversed eye worked well for me and greatly improved the ride IMO.
klawockvet is offline   Reply With Quote
Old 11-20-2017, 10:46 PM   #6
Chris Haynes
Chris Haynes's Avatar
Did you replace the main leaf or get a complete new spring?
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 11-20-2017, 10:51 PM   #7
SeaSlugs
SeaSlugs's Avatar
I thought there was a reverse eye spring in the hotrod section of the usual
A catalogs...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 11-20-2017, 11:27 PM   #8
chiliman
Just call Pete and Jake's they have every thing you need
chiliman is offline   Reply With Quote
Old 11-21-2017, 01:59 AM   #9
klawockvet
klawockvet's Avatar
I bought the whole spring. The super slider has a cup on the end of each leaf with a teflon (I think) insert. That is what makes them slide. I got mine direct from Posie. http://www.posiesrodsandcustoms.com but they are available from all the other dealers including Pete and Jakes, who I would go to again as they are great people to work with.
Old 11-21-2017, 08:49 AM   #10
Dave in MN
Dave in MN's Avatar
I ordered one from Snyder's Antique Auto Parts that fit and functions very well.
Part number: A-5310-RE Cost in the $2017 Catalog is: $147.00
Good Day!
Dave in MN is offline   Reply With Quote
Old 11-21-2017, 09:57 AM   #11
gardon
gardon's Avatar
Check speedway motors. I have one on my roadster. Priced right.
gardon is offline   Reply With Quote
Old 11-21-2017, 10:44 AM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
How well I remember prying apart Chrysler-Plymouth springs & replacing the pads ! Made a GREAT difference in the RIDE! It was quite EASY to do.
Bill Boing
"THE ASSISTANT GURU OF STUFF"
Old 11-21-2017, 07:06 PM   #13
1929
I have the Posie front reverse eye spring, I was contemplating on going back to the stock.
1929 is offline   Reply With Quote
Old 11-21-2017, 07:49 PM   #14
Chris Haynes
What is the problem?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 11-21-2017, 10:54 PM   #15
1929
I think I prefer the higher look that the stock gives,
Old 11-22-2017, 09:28 PM   #16
Chris Haynes
How far did it drop your car?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 11-22-2017, 09:40 PM   #17
1929
Bottom of the front bumper to the ground is 14 1/2 inches.
Old 11-23-2017, 12:25 AM   #18
Chris Haynes
How high was it before the drop?
1921 Runabout
1930 Tudor
Early 1930 AA
