Old 12-04-2014, 03:35 PM   #1
beerayb
Default Aluminum timing gear V8 60
Did Ford ever use these in production, or were they a replacement part? Ray
beerayb is offline   Reply With Quote
Old 12-04-2014, 06:33 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Aluminum timing gear V8 60
For a v8/60 I have never seen aluminum timing gears period , however I do know there were a few made by some one for race engines & also steel cam gears for racing.
I would love to find some Aluminum cam gears for a v8/60 .
Cheers
Tony
Old 12-04-2014, 08:16 PM   #3
34fivewindow
34fivewindow's Avatar
Cheers
Tony
Tony is the 50's Offenhouser made an aluminum cam gears for the 60's.
34fivewindow is offline   Reply With Quote
Old 12-04-2014, 08:19 PM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Are the gears in a 60 a different size than 85 and up engines? I haven't built a 60 for so long I cain't remember what the gears look like. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 12-04-2014, 08:25 PM   #5
KiWinUS
KiWinUS's Avatar
Thanks mate I did not know that. Kinda odd they did that as they were fierce midget competitors in that era
Old 12-04-2014, 08:26 PM   #6
KiWinUS
KiWinUS's Avatar
yep way different Walt .
Look similar.
Old 12-04-2014, 08:29 PM   #7
34fivewindow
Tony, Fred Offenhouser the flathead speed equipment maker, made the 60 gear.
Old 12-04-2014, 10:12 PM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
Cheers
Tony
Tony, here are pics of some aluminum timing gears from my stash. Early 85hp on left, 60hp on right. First is of front, second is of back. This 60hp timing gear carries part number 2709-A, nothing on this gear that mentions Offenhouser, but that doesn't necessarly mean they didn't make it. The aluminum 60hp timing gear was part of a collection of 60hp engines and engine rebuilding parts that I bought from a family in NJ. These parts had belonged to someone who had raced a hydroplane on the Delaware River. I called Rich Willim about finding these parts and had several conversations with him about how to build a 60hp engine that would produce 100+ hp.
John
Old 12-05-2014, 04:53 AM   #9
KiWinUS
KiWinUS's Avatar
Very Interesting !!
Thanks so much John , now you have me on the hunt !!!
Cheers
Tony
Old 12-05-2014, 06:00 AM   #10
BILL WZOREK
BILL WZOREK's Avatar
Is the Aluminum used in a timing gear have any special alloy for ware
And at this day & age with 3D Printers & CNC Machines wouldn't it be very possible to Get them made ?
I know $$$$ but it might be worth while to look into it.
Or find a retired Machinist to make you what you need ~ Just a thought ~
BILL WZOREK is offline   Reply With Quote
Old 12-08-2014, 12:52 PM   #11
beerayb
I think they would be difficult to make. The ones that I have the hub is steel and the rest is aluminum. Mine are identical to JM 35 SEDAN. The ones that I have are NOS. One has a Ford tag on it that reads 52-2709-A, the other two are NIB with V8 FORD stamped on left side of box tab and 2709A on the right side of tab with the letters written between in ink pen cursive Alum. Boxes are plain other than that. No Ford logo, no Offenhauser. They do appear to be factory made and all are identical. I'll let you be the judge. Ray
Old 12-08-2014, 10:04 PM   #12
beerayb
Back to original question, did any of these come off the assembly line, or were they replacements only? Thanks for info . Ray
Old 04-21-2019, 09:45 AM   #13
V860too
V860too's Avatar
Aluminum Cam gears were aftermarket only.
The OEM Fiber Gears would wear out quickly or break under the. "RACE CAM" spring pressures when turning them 7000rpm.
Was a guy in California remaking them but he passed away. He had not made any in 10yrs.
Have 2 guys racing each other now to get some back on the market.
I have a STEEL cam gear that someone made at sometime.
There were ALUMINUM Oil Pump Service Gears made by Ford.
The N series Ford Tractor uses the same INTERNAL pump gears and shaft bushing as a 60hp. But a 60 has a 22t oil pump gear and a Tractor has a 19t gear.
V860too is offline   Reply With Quote
Old 08-09-2019, 08:47 PM   #14
BP
Bought one today at the Stowe, VT car show & swap meet. Looks identical to the fiber one. No markings, looks like it was cast, them machined.
BP is offline   Reply With Quote
Old 08-10-2019, 01:37 AM   #15
Pete
Pete's Avatar
Dan MacEachern can make alum. gears for that. You do not need the steel hub.
He can do spur type also.
Old 03-29-2022, 07:58 AM   #16
kurtis v-8-60
would you sale the Alum gear for 100 bucks
kurtis v-8-60 is offline   Reply With Quote
Old 03-29-2022, 01:23 PM   #17
Ronnieroadster
Ronnieroadster's Avatar
I don't have any aluminum cam gears for the 60. However if anyone is interested I have aluminum oil pump gears the V-8 sixty available. Send me a PM for information.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
