Old 01-17-2014, 06:49 PM   #1
beerayb
Default Flywheel ring gear
Can a flywheel ring gear be removed and put on another flywheel? If so what is the best method? Thanks for all responses. Ray
beerayb is offline   Reply With Quote
Old 01-17-2014, 07:08 PM   #2
Kube
Kube's Avatar
Default Re: Flywheel ring gear
Without question, a ring gear can be swapped.
You will need to heat the gear. Do your best to do so evenly and try not to get it any hotter than necessary. You will be surprised at how little heat it takes to expand and subsequently remove that ring.
Installation is just the opposite of removal of course. I might suggest you have the "new" flywheel prepared and in close proximately to the "old" flywheel.
You may be fortunate enough to remove it from the old and place it directly upon the "new". If not, no worry... simply apply that heat again, Remember, apply the heat evenly and as little as necessary.
Kube is online now   Reply With Quote
Old 01-17-2014, 08:48 PM   #3
epw1949
Before heating and swapping your ring gear mark the location of you ring gear on your flywheel using your dowel pin holes for location.Now go to the flywheel your moving it to and by using the dowel pin holes locate the same location as the other flywheel,remove your ring gear with little heat, turn your ring gear a quarter turn,now heat it a little,and then it will fall on,make sure it seats all the way around against the flywheel.The reason you want to relocate the location of the ring gear,is your engine only stops at two locations,so when you start you engine its always at the one of the two locations on your ring gear.Hope this helps.E.P.W.
epw1949 is offline   Reply With Quote
Old 01-17-2014, 11:12 PM   #4
cmbrucew
cmbrucew's Avatar
I remove ring gears cold, and install them warm. The tip on quarter turn is good advice. another tip would be, lay 3 or 4 welding rods on the bench in a star pattern, lay the ring gear on the rods, then heat. less heat lost.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
