Old 08-03-2010, 09:45 PM   #1
CT Jack
CT Jack's Avatar
Default Voltage Converter
Looking for a +6v to -12v converter to run low power 12v accessory devices i.e. GPS, cell phone,etc.(5W-25W).
CT Jack is offline   Reply With Quote
Old 08-03-2010, 09:49 PM   #2
'29wagon
Default Re: Voltage Converter
http://www.theinverterstore.com
'29wagon is offline   Reply With Quote
Old 08-03-2010, 10:20 PM   #3
CT Jack
CT Jack's Avatar
Thanks for the reference but I am looking for a converter not an inverter. I want to convert +6v DC to -12v DC not AC. An inverter converts a square wave source to a sine wave.
Old 08-03-2010, 11:05 PM   #4
MCHinson
MCHinson's Avatar
Sort of expensive but this looks like it would do what you want...
http://www.batteryspace.com/dc-dcreg...torscable.aspx
If you want to build it yourself, this site has instructions:
http://www.aaroncake.net/circuits/6-12conv.asp
MCHinson is offline   Reply With Quote
Old 08-03-2010, 11:28 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Let us look towards our vendors to see what they have;
Here we go;"SIX TO TWELVE VOLT INVERTER - 2.5 AMP -
2.5 AMP output for radio with CD or tape. This higher amp is also required for CB's".
Old 08-04-2010, 08:00 AM   #6
John/CT
John/CT's Avatar
Here's where I got mine
http://www.rgclassictunes.com/BUYnow/accessory_page.htm
Make sure you order Model #PGPI-HC
6 volt pos ground -> 12 volt neg ground
John
John/CT is offline   Reply With Quote
Old 08-04-2010, 12:15 PM   #7
MAG
MAG's Avatar
Braton's PN 14940. 99.95. 2.5amp, 6 + to 12 -volt. 800-255-1929
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 08-04-2010, 12:32 PM   #8
Paul in Colorado
Paul in Colorado's Avatar
Woodyscustomshoppe on eBay has one for $59.
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230506080709
Paul in Colorado is offline   Reply With Quote
Old 08-04-2010, 12:47 PM   #9
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Or you can put a small 12V battery behind the seat and recharge occasionally.
Barry B./ Ma. is offline   Reply With Quote
Old 08-04-2010, 03:30 PM   #10
SANTA Ray
SANTA Ray's Avatar
I use a battery Jump Box. It has 12v DC 120 AC, air pump and a light. I connect a 10" extension (With 3 heads)to the box and run it under the seat to the fire wall. I plug in my GPS, phone charger and have an extra hole for whatever. The box sets on the rumble floor. I used this in June on a 2,952 mile trip and only charged it once in the Hotel at French Lick. This is simple and doesn't require any special wiring and gives multiple options. Total cost $59.00 and I can use it for other applications when not touring.
SANTA Ray is offline   Reply With Quote
