Old 09-07-2017, 01:39 AM   #1
aandkt
Default 1936 Cabriolet Regulator Gear
My drivers side window regulator jumps a gear tooth when I role the window up.
I removed the rivets from the crank gear case and found the gear warn and needs replacement. The problem is it has 12 teeth.
I can't find a 12 tooth gear for inside the crank mechanism of the '36 Cabriolet. I have seen 4, 6 and 10 tooth gears but I can't find a 12 tooth gear.
Any help would be appreciated.
Thanks
aandkt is offline   Reply With Quote
Old 09-07-2017, 07:17 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 1936 Cabriolet Regulator Gear
I have aconv sedan that had bad regulators, I found some kits at Hershey, had to buy the whole box---as you say the12 tooth is not common, I have the trim and hardware book, it has picture of the regulator, I looked in piles of unidentified (cheap) regulators at fleamarkets---found NOS and sold off the patched up ones for much more than I paid for NOS, sold off all the kits too, but I just found a small box with some regulator parts, but won't be able to look till the weekend
Have you tried "regulator Roy"-609 828 8537 ---he advertises in V8 times, and he has beat me out several times when we were both working through a pile of regulators (he just buys them all)
Old 09-07-2017, 08:15 AM   #3
Karl Wescott
Karl Wescott's Avatar
There are some $pendy window regulator repair parts for the 1931 slant windshield cars available from Snyders. I have not been able to compare them to the convertible but the photos and illustrations I have studied suggest the same design and possibly interchangeable parts. Snydersantiqueauto.com.
Karl Wescott is offline   Reply With Quote
Old 09-07-2017, 11:06 AM   #4
cmbrucew
cmbrucew's Avatar
Get someone to write a program for CNC mill. Make a bunch.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 09-07-2017, 01:16 PM   #5
aandkt
Thanks Guys
I have a call out to Regulator Roy now. thanks for the number Kurt.
I need that 12 tooth gear repair kit. It is only in the Cabriolet. If you find something that you think will work, please let me know. Snyders is next Karl
Old 09-07-2017, 07:51 PM   #6
Ken Bull
Ken Bull's Avatar
I sold an extra Regulator I had some time ago. One thought --if you removed the 12 tooth gear already ---find a Welder and have him build up the bad teeth and file them to be like new.
Ken Bull is offline   Reply With Quote
Old 11-26-2017, 09:32 PM   #7
aandkt
Good news for someone but not for me.
The 12 tooth gear from a model A fit a 1936 regulator BUT did not solve my problem.
When I crank the window up it goes about 4 inches and binds, then pops as though skipping a tooth. everything looks good, window moves freely without regulator so it is not in the tracks and I can't find problems visible in the gears. Reg Roy, although very pleasant, has nothing to help but, he did give me lead that did not pan out.
Now I am looking for another 36 Cabriolet regulator.
Old 11-28-2017, 08:58 PM   #8
wolfords
We had the exact same problem with our '36 Cabriolet. Half way up it would get on a bind and slip a tooth, so we put a small bracket so the regulator wouldn't twist or get in a bind and it took care of the problem. It was an easy fix really.
wolfords is offline   Reply With Quote
Old 12-16-2017, 11:13 PM   #9
aandkt
WOLFORDS
i DON'T UNDERSTAND WHERE YOU PUT THE "SMALL BRACKET
PLEASE ELABORATE AND IF YOU HAVE A SKETCH OR PICTURE IT MAY HELP.
Old 12-17-2017, 05:23 PM   #10
supereal
supereal's Avatar
The window regulators in my '47 convertible were worn out, and one was actually adapted from a closed car. The convertible regulators are special due to the weight of the stainless framed glass. Finding different ones was difficult, and I only found one, so we disassembled all the regulators and removed the gears. We then wire welded all the teeth, and reshaped them with a die grinder. They now operate like new.
supereal is offline   Reply With Quote
