04-03-2011, 06:19 PM | #1 |
another "Newbie" question.
While tinkering with my new "A" I noticed that the crank pulley is loose. While moving the fan back / forth I can see there is 1 - 2" of back & forth play on the crank Pulley (crank not moving). Was hoping the ratchet nut was loose & tried tightening the nut with the crank handle but did not help.
I assume there is a woodruff key on the crank/pulley. How major a job is this to repair. Any advice would be appreciated. Thanks, Leadpot |
04-03-2011, 06:31 PM | #2 |
Re: another "Newbie" question.
Looks like you got one of those no good 2 piece pullys. Yes it is a problem. Good idea at the time. Change it to a one piece!
04-12-2011, 12:19 PM | #3 |
Is the car ok to drive until I can get the pully replaced? Any danger of it coming apart. Sure don't want to damage the radiater.
Leadpot, |
04-12-2011, 12:50 PM | #4 |
If it's a typical cast iron 2 piece pulley it's already broke and just a heart beat away from flying off there in pieces.
Larry Seemann |
04-12-2011, 08:52 PM | #5 | |
If it is already a one piece, it might just not have been tightened down adequately; get a correct ratchet nut wrench and try tightening the nut. These things will take some torque. I've never been successful tightening it any other way. One other note: I got an engine back once where the "rebuilder" had put a lock washer under the nut. The nut would never tighten up, and I couldn't figure it out till I pulled the pulley. I would be surprised if this could happen again, but some other fool might have done the same thing with your engine. |
04-13-2011, 02:12 AM | #6 | |
replace it before you drive it again. i've not had personal experience with these, but have heard horror stories.
ESTRANGED CC |
