Old 10-24-2020, 05:07 PM   #1
samsonized
Default ford aluminum heads
i have a 35 cabriolet with an original flathead i am thinking i would like to install factory aluminum heads for looks. are there any pro's or con's to this
samsonized is offline   Reply With Quote
Old 10-24-2020, 05:10 PM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: ford aluminum heads
The only real con that I can think of is that aluminum heads tend to have increased corrosion and electrolysis issues over cast iron.
If you correctly maintain your cooling system it should not be an issue.
Old 10-24-2020, 05:24 PM   #3
Terry,OH
Terry,OH's Avatar
Since your car does not have the original heads, you have to make sure the pistons are flat top otherwise the original 35 style heads will not work.
Old 10-24-2020, 05:26 PM   #4
samsonized
i think it may have the original heads how can i tell
Old 10-24-2020, 05:36 PM   #5
Karl
Karl's Avatar
The originals would have been aluminum
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 10-24-2020, 05:38 PM   #6
samsonized
thanks
Old 10-24-2020, 05:40 PM   #7
koates
Fit cast iron heads and paint them silver and all your worries will be over. Regards, Kevin.
koates is offline   Reply With Quote
Old 10-24-2020, 05:41 PM   #8
samsonized
ok thanks
Old 10-24-2020, 06:30 PM   #9
Kube
Kube's Avatar
Pro? They are correct and unlike cast iron painted in an attempt to appear correct (they never do) the aluminum head will cool better albeit not enough to make a big difference.
Con? A good set of aluminum heads will lighten your wallet significantly.
Kube is online now   Reply With Quote
Old 10-25-2020, 05:48 AM   #10
Terry,OH
Terry,OH's Avatar
If the heads you have now have a part number embossed what is it? This could give you a good idea if they are for flat top pistons. Otherwise the best way to tell is to remove a head.
Old 10-25-2020, 07:57 AM   #11
hop up
hop up's Avatar
Hey Mike I have a few sets of aluminum heads but for flattop pistons. I can stop by the shop and show you them.
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
