Old 08-10-2020, 04:41 PM   #21
JSeery
JSeery's Avatar
Default Re: Front Fender Welting Sliding Out On '40
Originally Posted by philipswanson View Post
Now it says, "Cannot load the files because a Security Key is missing". Always something in the way. Never have luck posting pictures.
Phil, just email them to someone to reduce the size for you or post them. I can do it. [email protected]
Old 08-10-2020, 06:14 PM   #22
philipswanson
I already did.
philipswanson is offline   Reply With Quote
Old 08-10-2020, 06:59 PM   #23
V8COOPMAN
V8COOPMAN's Avatar
I also offered the same yesterday evening back in post #5. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-11-2020, 10:39 AM   #24
philipswanson
Already sent them a coupla days ago. Check your spam folder.
Thanks, Phil Swanson
Old 08-11-2020, 11:31 AM   #25
V8COOPMAN
V8COOPMAN's Avatar
OK, here are the pictures of the 'wandering welting' that Phil has been trying to post. DD
T5 W/TORQUE TUBE
Old 08-11-2020, 01:00 PM   #26
philipswanson
Thanks for posting the pictures. What the heck is a Security Token?
Old 08-11-2020, 01:36 PM   #27
Kube
Kube's Avatar
It appears there is an issue with the way it's (welt) folded over at the upper end. One should not be able to see the core when the welt is installed.
I believe if it was folded properly, that will cure the top issue.
The bottom appears to be a fitment issue, fender to cowl.
I suppose one could "cheat" and bond the welt in place...
Old 08-11-2020, 08:00 PM   #28
19Fordy
19Fordy's Avatar
Couldn't you just make the welting flange thicker?
First, loosen the fender bolts and see what's going on with the welting and the way it was installed.
Old 08-11-2020, 08:36 PM   #29
philipswanson
[QUOTE=19Fordy;1919226]Couldn't you just make the welting flange thicker?
How can you make it thicker, tape?
Old 08-11-2020, 08:37 PM   #30
philipswanson
Thanks guys for all the help!
Old 08-11-2020, 09:35 PM   #31
19Fordy
19Fordy's Avatar
[QUOTE=philipswanson;1919234]
Stick a strip of doubles sided foam tape on the welting, stick it in place and gently tighten fender bolts. In fact, the tape doesn't need to be double sided. Use weather stripping tape sold at Home Depot and try a small section first.
Old 08-12-2020, 09:25 AM   #32
TJ
TJ's Avatar
I'm using the Drake welting kits on my '40. Comes with pre punched holes which help keep it in place. You do need to finish the ends, but easy to install and good quality welting.
Old 08-12-2020, 05:23 PM   #33
JSeery
JSeery's Avatar
I already did.
Phil, seems the computer may dislike you! I found your email just now, it went to my spam file and the attached photos say "not downloadable". I have never had that happen before! Looks like coopman got them for you!
