Old 08-14-2020, 08:23 AM   #61
aussie merc
aussie merc's Avatar
Default Re: Dim Headlights on 40:
you could bypass the factory circut breaker with an aftermarket one you just need to know what the amperage is
aussie merc is offline   Reply With Quote
Old 08-14-2020, 09:22 AM   #62
JSeery
JSeery's Avatar
Not a bad idea.
Old 08-14-2020, 09:48 AM   #63
40ford
40ford's Avatar
I think the amperage would be 30 amps?
40ford is offline   Reply With Quote
Old 08-14-2020, 10:42 AM   #64
JSeery
JSeery's Avatar
I don't know the original CB amperage, but 30 amps should work. It will open up if it is overloaded which is what it is intended to do.
Just looked up a reference, 30 amps.
Old 08-21-2020, 08:25 PM   #65
40ford
40ford's Avatar
My problem solved.It was the circuit breaker.The one I took out looked very bad and corroded.
Old 08-21-2020, 09:13 PM   #66
deuce_roadster
deuce_roadster's Avatar
Good job, and you learned something about your electrical system!
deuce_roadster is online now   Reply With Quote
Old 08-21-2020, 09:17 PM   #67
JSeery
JSeery's Avatar
Good job!
