Old 11-19-2016, 05:55 PM   #1
silversink
silversink's Avatar
Default 29 coup trunk measurments
I need across the top , across the middle , across the bottom an dia. corner to corner, Mine has been smacked at the bottom of the left side in the wheel well so I'm going to have to rebuild the braces and what ever else it takes to get it back to where it belongs. Any help is appreciated.
Hotrods don't have valve covers
silversink is offline   Reply With Quote
Old 11-19-2016, 07:59 PM   #2
silversink
silversink's Avatar
Default Re: 29 coup trunk measurments
anyone?
Old 11-19-2016, 08:40 PM   #3
Kevin in NJ
I found you use the lid and make it all fit.
My cabriolet quarters were messed up. I was thinking I needed to do measurements and such. In practice I found you put the body together and work it all till it fits nice.
Kevin in NJ is offline   Reply With Quote
Old 11-19-2016, 09:24 PM   #4
silversink
silversink's Avatar
if I had a lid that would work
Old 11-19-2016, 11:45 PM   #5
700rpm
700rpm's Avatar
Originally Posted by silversink View Post
anyone?
I'll get out to the garage tomorrow and get some measurements for you.
Ray Horton, Portland, OR
Old 11-20-2016, 01:30 AM   #6
silversink
silversink's Avatar
thankyou
Old 11-20-2016, 01:57 AM   #7
pooch
pooch's Avatar
You are brave to push and pull a body based on someone else's measurements without a lid to work with first.
pooch is offline   Reply With Quote
Old 11-20-2016, 02:21 AM   #8
C26Pinelake
I why not invest in a lid and have something to start with? Some times mine not spent Is not money saved! Wayne
C26Pinelake is offline   Reply With Quote
Old 11-20-2016, 02:32 AM   #9
Manager
Manager's Avatar
3'3/4" at top 3'1/8" middle and 2'11 3/4" at the bottom. Sorry cant get a diagonal with the lid on and I'm not about to take it off.
And +1 to what Pooch said.
Manager is offline   Reply With Quote
Old 11-20-2016, 12:22 PM   #10
silversink
silversink's Avatar
I can pull the 36 1/8 in the middle with a ratchet strap from 36 3/4 . it bounces back when let off. time to start unbolting and adjusting to at least get the back bottom panel to bolt up. Thanks for the numbers
Old 11-20-2016, 05:27 PM   #11
700rpm
700rpm's Avatar
Since you have the opening measurements, maybe these will also be helpful;
I measured my trunk lid, and here's what I've got:
Front to back along the curve of the lid: 30-7/8"
Front to back straight from top of the lid to the bottom edge: 28-1/8"
Width of deck lid: 35-1/2"
Send me a PM or email if you need anything else.
Old 11-22-2016, 12:25 AM   #12
silversink
silversink's Avatar
thanks for the help---I got it real close and borrowed a deck lid from a friend and have close to a 1/4 gap all around----
Old 11-22-2016, 01:25 AM   #13
700rpm
700rpm's Avatar
That's about right. My lid is tighter at the top, though; about 1/8".
