09-07-2016, 04:34 PM | #1 |
rumble seat conversion, 29 coupe
Ma wants a rumble seat to take the grandkids in a parade. Does this panel need to be removed? (see photo and arrow, arrow is kinda faint)
If so, what replaces it? |
09-07-2016, 04:53 PM | #2 |
Re: rumble seat conversion, 29 coupe
there's a whole different panel that replaces that one. get an old used one as the replacement ones don't fit worth a damn.
Hotrods don't have valve covers |
09-07-2016, 05:03 PM | #3 |
Plenty of ole farts here wanting to change from rumble to trunk.
Just swap 'em the parts. |
09-07-2016, 06:09 PM | #4 |
That panel has to be replaced. You also have to drill a hole in the deck lid to accommodate the new location of the handle, and fill the old hole and repaint the lid. You will need to drill a hole in your fender for the step plate. You will want to figure out how to install seatbelts for the kids' safety. You will need a completely new hinge setup. You will have $1500-$2000 in costs, maybe more, to make the conversion, depending on how much you can do yourself.
Think long and hard about doing this. I converted my rumble back to a trunk because no one over 45 years old, 5' tall and/or 120 lbs could get in or out of it. My grandkids got too old to be interested. I got concerned about the safety of RS passengers in the event of a t-bone crash, even with seatbelts. And the trunk is just more practical.
09-07-2016, 06:44 PM | #5 |
I don't recall ever reading about a passenger in a rumble seat being injured or a car with a rumble seat being T-boned. I think sometimes we tend to over imagine! Wayne
09-07-2016, 07:42 PM | #6 |
09-07-2016, 08:28 PM | #7 |
In my opinion the only cars that should maybe have rumble seats are roadsters and sport coupes. Only these two car have a way to communicate with the driver and passenger - the roadster and sport coupe have panels that can be folded up to open the back of the cars. Otherwise the rumble seat occupants are left isolated - i.e out in the cold.
Rusty Nelson |
09-07-2016, 08:38 PM | #8 |
My 28 Sport Coupe has a rumbie seat that is the way it came new. But I wish it was a trunk.
09-07-2016, 08:51 PM | #9 | |
If the kids are small enough you can lift them in and out, and not drill for a step plate. |
09-07-2016, 09:32 PM | #10 | |
09-07-2016, 09:37 PM | #11 |
After 35 years of converting my 29 coupe to a rumbleseat, I converted it back to a trunk and glad I did.
Pluck |
09-07-2016, 11:16 PM | #12 |
Ill trade my rumble set up minus the seat springs for a trunk setup
09-08-2016, 06:22 AM | #13 |
might be easier to sell your car and buy another-or a swap with someone on the barn..........................
09-08-2016, 11:38 PM | #14 |
your probably right
09-09-2016, 12:41 AM | #15 |
09-09-2016, 06:10 AM | #16 |
I purchased a coupe once from a man who decided to sell it when his little daughter chipped a tooth when he had to stop fast and the lid closed on her.
09-09-2016, 06:21 AM | #17 |
I have my rumble lids positively locked by fabricated automatic latches with lap sash belts fitted.
I would like someone here to prove if this a fallacy or not that a stock rumble lid will in fact shut on itself under severe braking . I do not think it would. |
09-09-2016, 08:42 AM | #18 | |
05-23-2017, 06:21 AM | #19 |
Does anybody have good pictures of the curved inner panel ect, just starting with rumble seat conversion . iI have all parts listed in the Macs catalog.
05-23-2017, 08:10 AM | #20 |
Ford had the procedures which are reprinted in one of the "How to Restore" volumes. They give you a list of all the parts you will need.
The repro curved inner panel is not going to fit properly so you will need to adapt it. The front edge will need pan head screws. The rumble seat riser panel must have the re-enforcements solidly installed. They brace the rumble stops. If you have an original lid then you do NOT want to use reproduction rumble hinges. The will not fit without significant trouble. The repro appears to be a direct casting that shrinks in every direction. The originals fit the original rumble lid like a glove. The repro lower panel and the repro lids are straight across the bottom. They will tend to hit on the corners. Check your gaps or you are more likely to chip the paint in the corners. Take time at the shows and look at the rear panels and you will see the chip of paint I talk about. Now that you are aware of them you will always see them. |
Thread Tools | |
Display Modes | |
