Old 06-09-2014, 12:03 PM   #1
Jon-Ohio
Default 6V Batery recommendation
What's the best brand 6V battery for daily driver A ?
My local farm stores carry Exide 6V type 1 tractor batteries for $45 - are they any good or should I try NAPA, AutoZone, o'Reilly's or the like ?
Thanks for advice
Jon in Ohio
Jon-Ohio is offline   Reply With Quote
Old 06-09-2014, 12:07 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: 6V Batery recommendation
There are only 4 battery makes in the US so they are really all of the same. If you want one that will last go get an optima. They are three times the price but will last you three times as long.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-09-2014, 12:22 PM   #3
billwill
Id go to the Fam store goodluck
billwill is offline   Reply With Quote
Old 06-09-2014, 12:25 PM   #4
billwill
Smile Re: 6V Batery recommendation
You will do better at a farm store for Batteries good luck
Old 06-09-2014, 12:50 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
There are many names on batteries, but as mentioned, all are made by just a few companies. The STARTRITE 6 volt in my Model A is made by E.P.M. in Baltimore. I picked it out of the battery barrel at the junk yard over 10 years ago, and it's still going strong.
I just called a place about 4 miles south of me that sells E.P.M. made batteries, and he said a 6 volt would cost $76 and no trade needed.
Old 06-09-2014, 01:06 PM   #6
29 Tudor
29 Tudor's Avatar
I got mine at Tractor Supply and it seems to be fine. I swore off Optimas after having three of them go bad in under three years and the dealer (in California) would not warrant them without sending them back and leaving me with NO battery while they did that. I went to Wally World and bought new batteries for both vehicles (one uses two) and they have been fine ever since.
29 Tudor is offline   Reply With Quote
Old 06-09-2014, 05:15 PM   #7
Patrick L.
Patrick L.'s Avatar
Do you who it is that sells EPMs ?
Old 06-09-2014, 05:17 PM   #8
Patrick L.
Patrick L.'s Avatar
Didn't Optima have some quality issues lately ? I've heard the construction had changed and I haven't heard whether the issues have been corrected.
Old 06-09-2014, 06:34 PM   #9
d.
Default Re: 6V Battery recommendation
Tractor Supply Henderson NC area
I just called Tracto Supply this afternoon and they told me they no longer carry a Group 1 6v battery.
He knew what a Model A Ford was. Only 6v they have is for a lawn mower. He said all farm tractors now use 12v. How about a Farmall Cub or H?
He told me they are all 12v now.
d. is offline   Reply With Quote
Old 06-09-2014, 06:48 PM   #10
cedar
I bought mine at farm and fleet. Its a good battery.
cedar is offline   Reply With Quote
Old 06-09-2014, 07:11 PM   #11
glenn in camino
glenn in camino's Avatar
batteries have gotten more expensive and don't last as long as they used to. Optima dry cell batteries are the best.
glenn in camino is offline   Reply With Quote
Old 06-09-2014, 07:39 PM   #12
Tom Wesenberg
I would do a Google search E.P.M. Battery, and see what comes up. I think Deka is one name, as well as Startrite on my battery.
Speaking of batteries, I had a pleasant shock today when I put my battery charger on a 10 year 1 month old Fleet Farm battery. It showed a 2 amp charge on the meter, so I figured it was good enough to do some wiring and bulb checks in my Studebaker today. I put it in the car, then hit the starter expecting to hear nothing, but the engine spun like new, so it looks like I won't even have to buy a new battery.
Like I said before, I've always had many more years of life from a 6 volt battery than I've had from 12 volt batteries.
Old 06-09-2014, 07:58 PM   #13
SANTA Ray
SANTA Ray's Avatar
I just purchased one at Tractor Supply (Group 1) for $79.99. Was the best price locally in south metro GA.
SANTA Ray is offline   Reply With Quote
Old 06-09-2014, 08:20 PM   #14
jrelliott
jrelliott's Avatar
Had to get one earlier this year for the A and got it at O'Reilly as not too many choices in Payson, AZ. Surprise the caps come off and you can top off the water. If you can find them where you can top off the water they last a lot longer here in AZ. Had to get one for another vehicle that was less than 4 year old. Sealed Batteries do not last long in the AZ heat and low humidity.
jrelliott is offline   Reply With Quote
Old 06-09-2014, 08:24 PM   #15
spdway1
spdway1's Avatar
Interstate Battery...enough said.
spdway1 is online now   Reply With Quote
Old 06-09-2014, 09:20 PM   #16
Elcastor
Elcastor's Avatar
My Interstate Battery is still going strong. So far, so good!
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 06-09-2014, 09:28 PM   #17
Patrick L.
Patrick L.'s Avatar
It just don't get any better than an old Studebaker. Come to think of it, all Studebakers are old aren't they.
Old 06-10-2014, 02:36 AM   #18
Christoph
Christoph's Avatar
Jon - act as if its your own birthday....
Get yourself a OPTIMA and forget that you do have a battery
(It is "dry", you wont have to touch it for many years)
best regards Christoph
@JRELLIOTT
Sealed FLUID batteries are not really sealed.
take away the sticker and carefully open the upper-shell to refill water.
(Annul it, its just "clicked" in )
Sealed batterys are made with intransparent material. This is to prevent
that you see that its loosing water too. Manufacturers hope (!) that this batteries will survive time of warranty without refilling water.
(Be aware: If its really old the plastic-material of the upper shell might have lost its plasticizer and might break while trying to take it out....)
Christoph is offline   Reply With Quote
Old 06-10-2014, 07:28 AM   #19
zzlegend
zzlegend's Avatar
If it means anything, I have an optima in one of my A's and a one in my 54 chevy. Both 6 volt and purchased about 4 years ago. Both still work fine. I went to Cosco the other day to get a 12 volt for my Roadster and they don't carry them any more. The sales man said they had to many returns and warranty issues. Called my friend who sells them at his auto repair business and he said the same. He dropped them. Word is that optima moved their location and started using a different concoction to fill them. I ended up buying a Delco. Just my 2 cents.
zzlegend is offline   Reply With Quote
Old 06-10-2014, 07:34 AM   #20
Growley bear
Optima
Growley bear is offline   Reply With Quote
