Old 10-18-2020, 06:06 PM   #1
keyswitch1
Default lug nut removal
Yesterday I found a video on removing the model a stud but now I can not find it. Could you help me out please ??
keyswitch1 is offline   Reply With Quote
Old 10-18-2020, 06:29 PM   #2
redmodelt
redmodelt's Avatar
Default Re: lug nut removal
Why do you need a video to show you how to take off lug nuts?
Old 10-18-2020, 07:24 PM   #3
keyswitch1
My question was about removing the stud not the lug nuts or am I wrong ??
Old 10-18-2020, 10:32 PM   #4
Bob C
This isn't a video but is shows how to change the studs.
http://www.fordgarage.com/pages/swaging.htm
Old 10-19-2020, 12:03 AM   #5
redmodelt
redmodelt's Avatar
Please read your title, you ask about lug nuts. The question in the post was edited after I posted.
Old 10-19-2020, 12:13 AM   #6
Synchro909
Synchro909's Avatar
Where does the term "lug nut" come from? They go on the wheel studs so LUG nut??? Not confused, just curious.
Old 10-19-2020, 05:37 AM   #7
Dean Lemoine
Dean Lemoine's Avatar
“According to Google”.
The lug that shows up in lug nut or lug wrench doesn't seem to be directly connected. Instead, it comes from a word that meant a projecting part. Originally, it came from a Scandinavian word that meant the ear flap of a cap, or the ear itself. In the 1930s, lug also meant a lout, a sponger, a bozo, and a lowlife.
Dean Lemoine is offline   Reply With Quote
Old 10-19-2020, 10:15 AM   #8
katy
katy's Avatar
Probably comes from when using wood wheels, like on a Model T, there is a lug that goes between the wheel rim and the felloe of the wood wheel, and the "lug nut" tightens down against the lug.
Couldn't find a picture.
In Canada we just call them wheel nuts.
Old 10-19-2020, 10:29 AM   #9
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
In a nutshell, you need to purchase a swage cutter to begin with. I know some people will suggest using a hole saw instead however I do not have any experience using that and I could see where that could cause someone to get hurt.
The swage cutter I use slides over the threaded portion of the hub bolt and is turned slowly in a knee milling machine. The cutter slowly removes the area of the hub bolt where the bolt was riveted. Once this is complete, the bolt can be tapped thru the backside of the hub.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-19-2020, 04:24 PM   #10
Synchro909
Synchro909's Avatar
Yes, wheel nuts on wheel studs here too, just like manifold nuts on manifold studs. Strange!
