Old 07-07-2020, 01:45 PM   #1
fiddy6
Default 56 Victoria stock rear drums
I've been trying to source rear drums for a 56 Victoria with a stock rear end. Now I know MACs sell some but they are quite pricey and people I know have had quality issues with them in the past. I'm also on the other side of the world that doesn't help the price point either.
I wondered if anyone knew of a interchange part.
They are an 11" x 2-1/4" drum as far as I can tell and the wagons for 56 are different. I have no idea if the 55's are exactly the same.
Did the 54 have similar drums? I know from 57 the rear end changed and with it the brakes too.
Would raybestos 2626r work?
https://www.rockauto.com/en/parts/ra...626R,drum,1744
fiddy6 is offline   Reply With Quote
Old 07-07-2020, 02:30 PM   #2
JeffB2
JeffB2's Avatar
Default Re: 56 Victoria stock rear drums
No those are for a 10" drum they have been used on 1952-54 Fords. Your '56 had 11" X 1.75" brake shoes. You could use the 2626R if you switched to 1952-54 backing plates and shoes. I'm afraid Mac's has you over a barrel on those, those drums are also used on the popular 1957-59 Ford 9" rear ends they know how to make a profit.
JeffB2 is offline   Reply With Quote
Old 07-07-2020, 03:04 PM   #3
Dobie Gillis
Dobie Gillis's Avatar
Try cgfordparts.com. Their prices seem a bit more reasonable. I'm going through the same exercise for a '55 Merc. The fronts are 11 inch ID and take 2 1/2" shoes, the rears take 2" shoes, 5" bolt pattern. Anybody know of something more readily available for later FOMOCO products or even other makes?
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 07-07-2020, 05:00 PM   #4
51504bat
51504bat's Avatar
Concours in Carson City lists them:
https://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000051e~Z5Z5Z513607~ P134.95~~~~S5T
512HIFK47149118880i~Z5Z5Z5~Z5Z5Z50000051e
But as I guess you know they are not cheap. 170 bucks each with shipping
51504bat is online now   Reply With Quote
Old 07-07-2020, 09:15 PM   #5
Daves55Sedan
Daves55Sedan's Avatar
Looking at it from a different perspective, the '56 Victoria rearend is the same rearend that is used on '55 & 56 sedans, so if you knew of a junkyard that has a drum pile, maybe you could rifle thru it and find some good ones. Keep in mind, the wagons, T-Birds and F100 Trucks had a different rearend, so take a tape measure with you and make sure to match diameter and depth to your drums.
Old 07-08-2020, 04:06 AM   #6
fiddy6
Thanks guys. I wanted to make sure they have me "over a barrel".
I might upgrade to a more common rear end in future but my car is basically stock except for a wiper motor and distributor. I'm going to try to keep it this way a while yet.
Old 07-08-2020, 03:12 PM   #7
JeffB2
JeffB2's Avatar
For what you will pay for those drums you can just about swap to a later and much stronger Explorer 8.8 axle with disc brakes and a locker and stronger 31 spline axles. Maybe some one might know or has tried this,check out the prices on these drums and the shoes I looked up a 1979 LTD with a 302 and found these as dirt cheap deals so could you use these by also using the matching hardware kits and also the self adjuster kits for an additional upgrade ? https://www.rockauto.com/en/catalog/...+hub,drum,1744 Other possibility will the later model backing plates bolt up to the earlier rear end ?
Old 07-08-2020, 09:28 PM   #8
paul2748
paul2748's Avatar
The 8.8 swap is a nice swap, but not that easy as there has to be a number of modifications that must be made to get it fitting right.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-09-2020, 05:31 AM   #9
mobileparts
Fiddy6,
I have those brake drums in stock... But I am away at the Chrysler's @ Carlisle show right now....
Give me a call after the weekend... Always best to simply call me --- Craig ---
516 - 485 - 1935......
Yours, Craig.....
mobileparts is offline   Reply With Quote
Old 07-10-2020, 08:56 AM   #10
bobss396
bobss396's Avatar
Originally Posted by mobileparts View Post
Fiddy6,
Yours, Craig.....
This guy is the real deal and local to me, give him a try if you get stuck finding parts.
bobss396 is offline   Reply With Quote
Old 07-12-2020, 01:35 PM   #11
fiddy6
I found some locally. Ajays in Waihi had some. Still pretty expensive. Thanks guys.
