02-20-2020, 04:52 PM | #1 |
Is the brake master cylinder filled through a hole in the floor?
1950 F1
seems like a pain |
02-20-2020, 05:03 PM | #2 |
Re: Is the brake master cylinder filled through a hole in the floor?
Yes
02-20-2020, 06:01 PM | #3 |
Thx!
02-20-2020, 07:39 PM | #4 |
That's the way many older cars were. Very common. Not that hard to fill.
02-20-2020, 08:02 PM | #5 |
02-20-2020, 08:24 PM | #6 |
02-20-2020, 08:31 PM | #7 |
NO. You access the MC is through a hole in the floor. You fill it through the top of the MC. LOL LOL
02-20-2020, 08:46 PM | #8 | |
It's totally dry, but I don't see where the brake fluid has gone. It last had plates in 1985. |
02-20-2020, 08:58 PM | #9 |
Man I love my cars with mechanical brakes!
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
02-20-2020, 09:17 PM | #10 |
Check your wheel cylinders and flexible lines, probably seals all shot
02-21-2020, 08:10 AM | #11 |
it,s very ez to adopl a remote fill. if you stay with the org. fill cap do not tighen cap with a wrench just tigthen it hand tight. if you make it to tight you will never get the cap off later on
02-21-2020, 02:50 PM | #12 |
Some of the master cylinder repop units (including the NAPA version) have the dumbest design possible for the cap/throat. Impossible to add fluid without making a mess, they compound the fun by preventing any means to guage the fill level. So, you can't assure adequate fluid and any attempt to top things off is rewarded with a puddle on the floor.
Fortunately, the old, simple, foolproof screw cap fits - replace the 'new' one with it and live happier.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
02-21-2020, 08:10 PM | #13 |
I got a remote kit for my 36 that uses a 39 M/C from
EZ-FILL remote reservoirs at http://highway101ind.com/ It works great, not a pain in the ass to check your fluid level, I did cut a hole in the floor right above the cap just cause I might need to look there sometime. Now you can't hide it, and it isn't stock looking, but I'm not a point seeker. |
02-25-2020, 08:03 PM | #14 | |
Anyone know of a dual reservoir MC that will fit under stock floor without cutting? |
02-26-2020, 06:46 AM | #15 |
I grew up in my fathers shop when all makes, the cylinder was under the floor most were
not bad but those Chrysler Prod's the cylinder was tucked behind the steering box between the pedals worse yet the fill hole was only a 1/2 inch pipe plug. So my father for as long as I remember was the red rubber bulb with tube like a turkey baster. That was part of a grease / oil change service even that yellow stuff rubbed on the door striker 'locks'... |
