10-19-2020, 10:14 PM | #21 |
Re: Does Anyone Know What This Is?
The other option is that it could be a series choke coil, connected in the power feed to the radio in an effort to reduce high frequency Ignition and/or Generator noise being passed through the power feed to the radio?
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
10-20-2020, 12:13 AM | #22 |
Either turn the radio off or throw it away. Tune-up that flathead engine and listen to that "beautiful music" while toolin' down the road! Simple, affordable and gratifying solution. DD |
10-20-2020, 11:32 AM | #23 |
Not so fast; maybe he likes the crop reports and foreign language stations so common on AM radio these days. I even found one up here in Minnesota that plays Mexican music that sounds like "Old-Time" polka music to me. You know, trumpets and oomp-pa tubas and accordions. I got kinda used to it.
10-20-2020, 12:16 PM | #24 |
If in NYC area, we still some decent talk radio stations around on the AM dial. That's if you can stand the static.
10-20-2020, 12:24 PM | #25 |
Don't forget that there is a difference between a two way radio transceiver antenna and a plain old radio receiver antenna. All a regular car radio needs is an antenna that will receive signals of a frequency range depending on the receivers frequency band. An AM radio only needs a simple antenna and any coils will usually be inside the radio set.
A transceiver antenna can be a bit more complicated. Ignition noise, generator noise, or what have you, can be filtered with a capacitor in the noisy items power line. The King Seeley senders sometimes had caps on them too. The Motorola 60 was not a Ford standard option. The Motorola 60P was actually a police radio made from the model 60 and they are kind of big in either case. They were a reciever and they did have a load coil system. Here is a link with some info. http://www.wb6nvh.com/Moto/Motadata.htm They mention a magic eliminode system for these. The eliminode system was supposed to be a noise eliminating dual antenna system with one antenna to eleminate noise and the other to pick up the radio frequencies. I don't think this system lasted very long. Here is a diagram link. http://www.nostalgiaair.org/PagesByM...2/M0006702.pdf Car radios were still kind of a new thing in the mid 30s so a lot of different things were being experimented with. Those Motorola Model 60P receivers were likely among the first police band receivers put into wide use before Police bands got out of the AM frequencies and went to VHF. Last edited by rotorwrench; 10-20-2020 at 01:13 PM. |
10-20-2020, 01:03 PM | #26 |
10-20-2020, 01:15 PM | #27 |
During my first four years of a career with the FAA, I was in an engineering group that traveled extensively doing evaluations and mods on outlying navaids. As such, I spent an awful lot of that time in South Texas, down in the neighborhood of our southern border. 'Chalupa' music is just about all that could be found on a radio down that way, especially back in the '70s. Drove me bonkers, 'cuz it ALL sounds the same. DD
10-20-2020, 01:55 PM | #28 |
Certainly looks like some sort of inline noise suppression device i.e. what looks like a capacitor in the middle with a coil wound around the outside.
10-20-2020, 04:31 PM | #29 | |
10-20-2020, 06:31 PM | #30 |
The usual Philco and Zenith radio sets are more common but there were aftermarket sets targeted to all the domestic cars that were more popular. The Philco FT6 was the most common.
