Old 10-19-2020, 10:31 AM   #1
edzaha
Default Rivets
Can someone tell me diameter and length of rivets for the bottom of the firewall to body? TIA.
Ed
edzaha is offline   Reply With Quote
Old 10-19-2020, 10:52 AM   #2
54vicky
54vicky's Avatar
Default Re: Rivets
probably help if you note what you are working on.kreskin left the building some time ago
54vicky is offline   Reply With Quote
Old 10-19-2020, 12:05 PM   #3
edzaha
Default Re: Rivets
31 Vickki sorry
Old 10-20-2020, 10:14 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Rivets
The rivet length should be equal to the thickness of the structural joint plus 1.5 times the rivet diameter.
Bob Bidonde
Old 10-20-2020, 10:35 AM   #5
edzaha
Default Re: Rivets
Part of the the question was what is the diameter rivet used?
Old 10-20-2020, 12:00 PM   #6
rotorwrench
rotorwrench's Avatar
Default Re: Rivets
The tail end can be between 1 and 1.5 the diameter of the rivet on steel parts. A lot depends on the diameter of the hole and whether they have to be driven hot or cold. I have no experience with the Victoria so I don't know the diameter of rivets used. Ford used a lot of 3/16" rivets for model A bodies. Some were round head and some were the flatter & wider truss or brazier head. Frames generally use the larger diameter rivets and they are best driven hot. Big Flats Rivet is a good place to look for rivets. They have some good info on there.
I generally just measure the hole size and get the closest rivet available for that size but holes can be welded up and redrilled if they are larger than they should be. I get the rivets that are closest to 1.5 D longer than the thickness of the joint. A person can shorten them if they have to but that is a safe way to order them. The head type depends on what Ford actually used. If a person has an example them measure the head diameter since that will tell you something and whether it's a round head or truss type will tell you another.
Ford had big hydro pneumatic squeezers to set the rivets. We have to use big rivet guns or hammer tools if you don't have rivet guns and sets.
Old 10-20-2020, 12:16 PM   #7
edzaha
Default Re: Rivets
Thank you!
Old 10-20-2020, 10:42 PM   #8
CWPASADENA
CWPASADENA's Avatar
Default Re: Rivets
I found the rivets used to attach the firewall to the sub rails were all 3/16 dia.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 10-21-2020, 10:04 AM   #9
edzaha
Default Re: Rivets
That's what I just ordered thanks!
