Old 10-13-2020, 07:02 PM   #1
jack wingard
Default Knocking on start up
On a cold start up there is a 30 second engine knock briefly. Where should I start to look?
jack wingard is offline   Reply With Quote
Old 10-13-2020, 07:44 PM   #2
40 Deluxe
Default Re: Knocking on start up
Drop the pan and check for a worn rod or main bearing. They knock worse on start up until they get oil. Sometimes a worn/cracked piston will rattle for awhile until it warms up a little and expands.
Old 10-13-2020, 07:48 PM   #3
Synchro909
Synchro909's Avatar
I'd start with a check of the main bearings, The rods get oil from the first revolution, not after 30 seconds which is about right for loose main bearings. Adjust them to 0.0015" and you'll be on your way for many more miles.
Old 10-14-2020, 10:11 AM   #4
katy
katy's Avatar
I once had a 302 engine that knocked like that for a few seconds. The fellow at the machine shop told me it was piston slap until the pistons warmed up and expanded. I dropped the pan, replaced all the rod shells with .001" undersize (oversize?) shells, knock went away.
Old 10-14-2020, 10:36 AM   #5
WHN
I’m not a big fan of rushing in and taking things apart. If the engine runs good, isn’t smoking or using any oil, and is quite after 30 seconds?
I would do one thing first. Change the oil. Put in 20w-50 HD and one blue bottle of STP.
I have saved a couple of engines over the years from what some people felt needed a major overhaul, to many more happy miles. These cars are not as quite as your Ford Escape or your neighbor’s BMW.
Please no negative comments, this is just my opinion. Advice is free.
Enjoy.
Old 10-14-2020, 10:49 AM   #6
jb-ob
WHN 2X
I'll add to WHN, with the ignition key off, step on the starter for 10 - 15 seconds. Listen carefully as the engine sound will change as the oil from the pan is pumped up to bearings etc.. Then turn on ignition & start normally.
Diagnose from simple (cheap) to complex (expensive).
jb-ob is offline   Reply With Quote
Old 10-14-2020, 10:50 AM   #7
Jim Brierley
It's probably loose main bearings as Syncro909 says. I had an engine that did that, and leaked out the rear main like you wouldn't believe. It may be time for a complete rebuild.
Old 10-14-2020, 11:20 AM   #8
Y-Blockhead
Y-Blockhead's Avatar
A couple of years ago the engine in my Town Sedan started knocking at start up. I pulled the pan and found this lovely site. Not saying you lost a bearing but you may consider checking. All the "parts" were in the dipper tray so nothing showed in the oil.
Old 10-14-2020, 04:45 PM   #9
jg61hawk
WHN hit the nail on the head....rebuild an engine for what...to drive 400 miles a year?? Is this a daily driver.... up the oil viscosity, STP added and live with it for years and years I'll bet.
jg61hawk is offline   Reply With Quote
Old 10-14-2020, 09:28 PM   #10
eagle
eagle's Avatar
Its a simple matter to pull the pan and check it out. Should be done once in a while anyways. The bearings have wafer thin shims that you take out to tighten.
Old 10-15-2020, 05:50 AM   #11
jack wingard
Thanks for all the advise. Over the winter I'll probably pull the pan and check things out.
Old 10-19-2020, 11:52 PM   #12
AZ_Nick
Exactly. We're not talking about rebuilding the engine, just adjust the shim stack to spec and off you go.
AZ_Nick is offline   Reply With Quote
