Old 04-18-2019, 03:05 PM   #1
Del in NE Ohio
Del in NE Ohio's Avatar
Default Drum Tail light brightness
I am helping a friend with his ‘28 Tudor for touring . He’d really like to keep the single drum style lamp. What can we do to make it brighter?
Del in NE Ohio is offline   Reply With Quote
Old 04-18-2019, 03:26 PM   #2
Jw
Default Re: Drum Tail light brightness
make sure the ground is good, run a wire from the "grounded" portion of the bulb directly to the grounded portion of the battery terminal, or are there "lower voltage" bulbs?
Jw is offline   Reply With Quote
Old 04-18-2019, 04:02 PM   #3
Jim/GA
Jim/GA's Avatar
Yes, make sure you have a good ground.
You can buy an LED light insert that works with the drum style tail light. They are really bright!
Jim Cannon
"Have a Model A day!"
Old 04-18-2019, 04:06 PM   #4
Brian SATX
Brian SATX's Avatar
Also, Snyder's sells bulb that are about twice as bright as the standard bulps for 6V
Brian SATX
Brian SATX is offline   Reply With Quote
Old 04-18-2019, 04:23 PM   #5
Del in NE Ohio
Jim, who sells the Drum tail lamp compatible LED plate?
Old 04-18-2019, 05:26 PM   #6
Jim/GA
Jim/GA's Avatar
Bratton's:
https://www.brattons.com/6-vt-driver...ail-light.html
To get the green card with the LEDs to sit up close to the lens and shine out the best, wad up a small piece of bubble wrap (the type with the really small bubbles -- about 1/4" bubbles) and stuff it behind the green card before putting drum back on.
Pretty easy to install.
Be sure to order either 6 V pos. gnd. (above link) or 12 V neg. grd., whatever your car is.
Jim Cannon
Old 04-18-2019, 06:07 PM   #7
jlambert
I have installed led's from Bratton's in my drum tail light and my tea cup tail light. The tea cup tail light was very simple to install. The drum tail light led is a little tougher to install. I had to glue the green card to the dividing plate to get it to stay in place. I then put some foam rubber behind it. Both are very bright and safer. You will not be disappointed in the results.
Good luck
28 phaeton
30 coupe
jlambert is offline   Reply With Quote
Old 04-18-2019, 07:12 PM   #8
mhsprecher
mhsprecher's Avatar
LEDs are good. You can also paint the inside of the tail light housing white. That helps a lot, too.
mhsprecher is offline   Reply With Quote
Old 04-19-2019, 07:28 AM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Use APPLIANCE WHITE.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-21-2019, 01:47 AM   #10
M2M
M2M's Avatar
Originally Posted by Jim/TX/GA View Post
There's one thing I don't get, how are these LED inserts MORE expensive than complete LED stainless steel tail light assembles, see:
https://www.brattons.com/6vt-red-amb...mbly-left.html
M2M is offline   Reply With Quote
Old 04-21-2019, 06:53 AM   #11
chap52
chap52's Avatar
I know that the purest will cringe, but. People are not accustomed to looking down to see tail lights anymore, just cell phones. I installed an led third brake light from Berts in the rear window of my Tudor. Has a low profile and when it comes on, it's an attention getter. I just hooked it up as a brake light even though it will also work as a turn indicator. Chap
Old 04-21-2019, 08:49 AM   #12
30 Closed Cab PU
A link to what I use, explore the site, a lot of good info. If you email/call them you will get what you need. I believe both are BA15d. Can not find my paperwork, would give you the part #s if I could find the paperwork/receipts. Just plug and play.
I f I remember correctly they have been discussed on her before, Do a search on Dynamo regulator for more info.
Here is the link
http://www.dynamoregulatorconversions.com/
Old 04-21-2019, 11:01 AM   #13
MNFATS
MNFATS's Avatar
I have had good results using aluminum foil formed inside the reflector as a quick fix on all my old cars.
MNFATS is offline   Reply With Quote
Old 04-21-2019, 09:04 PM   #14
Pete
Pete's Avatar
It has been a long time but I think we used a 32 by 50 headlight bulb in the tail lights.
As I recall, it just plugged in.
Pete is online now   Reply With Quote
Old 04-21-2019, 09:17 PM   #15
jimalabam
jimalabam's Avatar
Hey CHAP 32 - Nothing wrong with being a Purist AND adapting a SAFETY ITEM...
jimalabam is offline   Reply With Quote
