10-10-2011, 08:15 PM | #1 |
Brake fluid
I once in a while wonder if I could heat dot3/4 brake fluid from a long opened, one gallon can to eliminate the water content... Maybe to 250-280 degrees?
Looking for opinions... Karl |
10-10-2011, 08:54 PM | #2 |
Re: Brake fluid
DOT 3/4 is too cheap to take any chances with it. You could probably boil the water out of it, but why. Brakes are rather important, don't you think?
10-10-2011, 09:27 PM | #3 |
Re: Brake fluid
Why??? Not worth it.When you don't have brakes you are putting it all on the line.Your vehicle,your life other people's life.My opinion to risky.To many unknown factors. JUST MY 2cents lee34
10-10-2011, 10:02 PM | #4 |
Re: Brake fluid
Dot3 or 4 is cheap. I think you can buy a quart for less than $20. Why take a chance on old fluid? You may not get all the moisture out of the can by heating it and therefore you may wind up with rust in the system sooner than later. You are also wasting a lot of time and energy trying to save old fluid. Doesn't make sense to me. JMHO
10-10-2011, 10:23 PM | #5 |
Re: Brake fluid
Think you want to heat it? Start fire & VERY CAREFULLY pour some on it & you may want to change your mind about heating it. Much safer & cheaper to buy new.
10-10-2011, 10:52 PM | #6 |
Re: Brake fluid
10-11-2011, 03:36 AM | #7 |
Re: Brake fluid
Karl-
Common brake fluids contain a wide range of chemical compounds, including: oil, butanol, alcohol and esters. Many of these ingredients can become very flammable in an unconfined vapor state which boiling could/would release at sub-water boiling temperatures (212F). If this is the case, I would think any an attempt to boil out the water would create substantial vapors which are not only highly flammable but they will not add to your lungs' longevity. Needless-to-say, what you are thinking about doing has the potential of giving you a really "bad day!" Why run the risk? Buy new! Tom |
10-11-2011, 08:23 AM | #8 |
Re: Brake fluid
Heat, especially higher temps, have a tendency to change the chemical properties of the substance being heated. Lower temps like just below the boiling point of water would still evaporate some compounds while not affecting others. You will get the water out but will likely remove some other compounds that should remain there. Even relatively low moisture content DOT 3 brake fluid will still absorb moisture even after it is put into the brake system. As was mentioned several times earlier, it's not worth the risk. Brake fluid is still relatively inexpensive.
Kerby |
10-11-2011, 09:58 AM | #9 |
Re: Brake fluid
its so inexpensive and your time is worth something so i only buy it from a big chain store so its cheap and i only use new stuff.
