05-12-2011, 10:58 PM | #1 |
Assembling 1939 Tudor HELP!
I am in the process of putting my 1939 Tudor Deluxe back together, after a long time apart... Memory does not hold up... I am hoping some one near me has an original or near original car that I might take a look at, from under side...
Specifically looking for speedo cable and park brake cable routing along frame and thru firewall... (Probably something else also) I am in Marin County, just north of the Golden Gate bridge... Phone is 415 435 4800... I am grateful, in advance for your kindness... Karl |
05-12-2011, 11:59 PM | #2 |
Re: Assembling 1939 Tudor HELP!
I can try and take some digital photos of mine this weekend. It's a mostly stock, original car.
05-13-2011, 12:43 PM | #3 |
I think the brake cable is debatable, but the concensus is that it runs from the handle, through the 'U' opening (in the wood toe board) between the steering mast and the firewall, You will see the firewall has a small cut out where the wood rest on it that the cable passes through. Then down the x-member.
05-13-2011, 06:06 PM | #4 |
Thanks , Mike 707 217 8751 |
Thread Tools | |
Display Modes | |
