04-15-2011, 03:47 AM | #1 |
'51 Ford Tool needed
To remove dash bezels on a '51 requires a small round tool that has four spokes on it. I tried using a blade screw driver but it makes a mess of the bezel and can't get things tight. Does anyone know of a source or substitute for this tool?
Thanks Tom |
04-15-2011, 05:56 AM | #2 |
Re: '51 Ford Tool needed
I took a piece of steel gas line and filed it off leaving 2 prongs and used a pair of pliers and turned it right off.
04-15-2011, 06:03 PM | #3 |
Thanks Cecil for the tip!
Tom |
04-15-2011, 07:18 PM | #4 |
I bought one at Mac's in Lockport 2 years ago. It cost about $8.00. It was not listed in their cataloge, but at the time I called them, they had them in stock.
04-15-2011, 08:26 PM | #5 |
These are readily available through the old car parts houses. They have two prongs. The TBird parts houses also sell them. I think they are called Bezel Nut Tools.
04-15-2011, 08:56 PM | #6 |
SW-FLORIDA |
04-17-2011, 07:43 AM | #7 |
I use one of my wife's pickle forks. Cut the center tine out, cut the tips off the other two & bent them over 90%. Works great on bezels, but not so good on pickles
Butch In a world filled with stress it is better to give than to receive. |
04-17-2011, 08:28 PM | #8 |
I have used two small screwdrivers and levered them behind the shaft (choke rod, throtle rod, light switch rod, etc) that comes out of the bezel.
